Cool Riding pics from 7-3-08
   / Cool Riding pics from 7-3-08 #21
the guy who owns the property we ride on has a 700 man it's nice he is keepin the stock tires on it though (what a waist). i would put some better tires if it was me but thats him.
It sounds like the new Grizzly 700 is what I will start saving for. Is the Grizzly still a single cylinder, I hope so, as we have all hydrolocked our machines more than once , and it seems as though the single cylinders just quit running, and once you drain them out , they are fine,[at least so far!!!!]. Everybody that I know who has hydrolocked a twin has grenaded it, [both big bore polaris 4 strokes] I realy don`t think it has anything to do with brand, I am thinking that water just stops a single cylinder most of the time, where on a twin, [or any multiple cylinder engine] when one cylinder initialy hydro`s the other is still trying to rotate the engine and causes catostrophic damage.
   / Cool Riding pics from 7-3-08 #23
There's a reason all the big bore 4x4 are belt drive. They work so well. The belt drive will ramp up the gearing smoothly. A manual would have to drop traction to shift. the autos will gear down also as you go down a steep hill.
On my brute I almost never touch the brakes, it has a clutch kit as well as few other mods;) . Have you took a look at high lifters website?
   / Cool Riding pics from 7-3-08 #24
yea them belts are strong if they wasn't people would be poppin belts instaed of cracking 3/4 to 1" shafts . so whats stronger rubber or iron.lol
   / Cool Riding pics from 7-3-08 #25
yep. I've only been through one belt. I hammered throttle in sticky mud while in high range. :rolleyes: Been through 2 axles though. 29.5 outlaws spinning in mud and then grabbing on a root snaps stock ones.Now there's gorillia axles in the back.
   / Cool Riding pics from 7-3-08 #26
We should rename this thread to "Why one should seriously consider buying new stuff instead of used"
D.
   / Cool Riding pics from 7-3-08 #27
i only really use the brakes if i'm goin down into a ditch other than that the engine brake pretty much stops the rhino or atleast brings it to a slow crawl.i bet the engine braking would do really good on a hilly ride.
   / Cool Riding pics from 7-3-08 #30
loods like stock tires, that plus low clearence on those side by sides. My grizzley with itp mud lites wouldn't even know a mud hole was there =oP. Before the grizzly though I used to wheel with a 2wd yamaha and that thing would sniff mud and get stuck.
2025 CFG Industrial MX12RX Mini Excavator (A59228)
2025 CFG...
Pull-Behind Batwing Rotary Brush Cutter Attachment (A59228)
Pull-Behind...
(22) Assorted Webbing Slings (A57453)
(22) Assorted...
Man Cave Metal Sign (A57454)
Man Cave Metal...
6ft Teakwood Indian (A57454)
6ft Teakwood...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
