cool air in a 2538 cab?
   / cool air in a 2538 cab? #1
DarkHelmet
Saratoga,NY
Mahindra 2538 HST Cab
Does anyone have an idea on how to get cool fresh air into the cab without using the A/C when it's not warm out? If I keep the A/C off and the fresh air vents open, or closed, I end up just getting hot air into the cab no matter what the temperature is outside. Is there some trick to making this work? Don't see a reason why I'd kick on the A/C when the temp is 70.
It sucks that they didn't make a way to vent air through the cab. If you open the back window you don't get any flow at all because there's no way for the air to get in.
   / cool air in a 2538 cab? #2
You are in a fish bowl,just run the A/C.Run mine at 65 F.
   / cool air in a 2538 cab? #3
If the sun is shining and 70 degrees, it’s going to get warm in there without the A/C on.
You can usually take the doors off a tractor without much hassle.
   / cool air in a 2538 cab? #4
I've run the a/c when the outside temps are in the 30's because if you didn't it would roast you out. I don't know if the smaller cab of a 2538 heats up quite like the large cabs on Case/IH Magnum MX series or not.
2015 HINO CONVENTIONAL TYPE TRUCK (A52472)
2015 HINO...
(10) 2 PLUG VALVES (A52472)
(10) 2 PLUG VALVES...
2017 Ford F-550 Ext. Cab Valve Maintenance Vacuum Service Truck (A50323)
2017 Ford F-550...
Case 588G (A50120)
Case 588G (A50120)
2014 Kubota B2320 (A50120)
2014 Kubota B2320...
