Thumb Converting Woods BH90x thumb from mechanical to hydraulic
   / Converting Woods BH90x thumb from mechanical to hydraulic
I did not make any progress this fall. Might take it up again in the spring but not before as my tractor is currently hibernating.
   / Converting Woods BH90x thumb from mechanical to hydraulic #12
IT, did you end up doing this?
No, I think about it occasionally but I don't even use the thumb anymore. I used it a lot when I first started ripping out trees but I've pretty much cleared those trees now and I don't really need a thumb for the general digging work I typically do with the BH.
The thing that stymied me was finding the right hydraulic cylinder. It really has to be a near perfect match in length to avoid doing damage. The hydraulics are not such a big issue though there would be some expense involved.
   / Converting Woods BH90x thumb from mechanical to hydraulic #14
Did you look a buying just the cylinder from Woods?
I don't remember if I did or not. Good idea though. They must sell them as replacement parts.
   / Converting Woods BH90x thumb from mechanical to hydraulic #16
MIE sells a hydraulic thumb for the woods BH, you should be able to get hoses/valves/cylinder from them.
Thanks Jim. I got my ripper from MIE so I know them well. If I decide to reactivate this project I'll give them a buzz.
2017 Nissan Versa SV Sedan (A53424)
2017 Nissan Versa...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2023 Polaris Ranger SP 4x4 Utility Cart (A55787)
2023 Polaris...
Husqvarna Z 248F 48in Zero Turn Mower (A55851)
Husqvarna Z 248F...
250ft Roll of Copper-Clad Aluminum Building Wire (A55852)
250ft Roll of...
Engel 20' Boat (A50121)
Engel 20' Boat...
