Converting to TLB-style engine speed control
/ Converting to TLB-style engine speed control #1
dfkrug
Super Member
Santa Cruz Mtns, CA
05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
I just converted my Kioti tractor over to the TLB-style engine speed
control, from the standard dash-mounted lever.
Tractor-Loader-Backhoes (TLBs) have their engine speed controls accessible
to the driver while operating the hoe OR drving the tractor. My Kubota
B21 used a control lever on the right fender and it was very comfortable and
easy to use. Much easier than leaning over or stretching to reach the dash-
mounted lever.
My tractor is a HST, but you still need to set the engine speed on gear
tractors when using a hoe. First photo shows where the cable acts on the
FI system. Two cable controllers can be used, retaining the dash-mounted
unit, or using a foot controller. I tossed my OEM dash-mounted unit
because I stole its friction disk.
I bought a 67" cable with bulkhead mounts at each end and high quality
wire rope cable. I found just the right size from a dealer who sold me
a brake control cable for a Puch scooter.
2nd photo shows the raw weld-up. This bracket will be mounted inside the
frame that supports the 3-pt lever and the AUX hyd lever(s).
Final photo shows the finished installation. My new lever operates in the
slot reserved for the draft-control lever. Works great!
/ Converting to TLB-style engine speed control #2
That looks cool:) I think that is a great upgrade, well thought out and looks like factory.
/ Converting to TLB-style engine speed control #3
That is a great modification. I really hate how I have to stretch to reach the throttle on my b3030 when using the hoe.
Vic
Thx for the support, guys. Feel free to copy at will.
/ Converting to TLB-style engine speed control #6
Good job!
Don
/ Converting to TLB-style engine speed control #7
Hey Dave,
Wonderful and very nice mod. Your work is super clean too.
That gives me the incentive to either re-locate or lengthen some levers on our tractors. They work now, but often are hard to reach. It's one of those things we've been living with but could sure use some upgrading.
Rob-
Thanks, guys.
Rob, I bought a control cable from Surplus Center that was intended for
hydraulic control, and, unfortunately, I could not use it for this application.
It seems many newer tractors have gone with remote cable-operated
spool valves and my Kioti has those. The cable from SurpCntr was very
stout with stainless steel bulkhead connections at each end and designed
for push and pull operation in a harsh environment. It was only $15, but
too thick (and short) for my speed control. You might want to use cables
like those for remote control of your levers.
