Loader Converting to skid steer attach on 20 series
   / Converting to skid steer attach on 20 series #1
hammick
Montana
LS MT357HC
Not a lot of info on converting my 4020 to SSQA. Mine is a 2002 model. I understand they now come standard with SSQA.
I don't want to use an adapter that adds weight and puts the bucket out farther. Are there any options for a straight conversion? If not, does Branson make blank plates that I can weld on to say pallet forks to use with the Branson quick detach system?
Thanks for any advice.
   / Converting to skid steer attach on 20 series #2
Can you provide a picture of what your system looks like now?
I'm picking up the tractor in about 10 days so I don't have a good photo but below is a link to a post and photo from a previous thread many years ago. The Branson QA is similar to Euro but different enough that Euro attachments don't fit (or so I've read).
http://www.tractorbynet.com/forums/century-branson/356600-bl20-quick-attach-type.html
My dealer can get a set of custom made forks that fit my Branson quick detach for $600. Lightweight at 225lbs. Done deal.
   / Converting to skid steer attach on 20 series #5
I ended up waterjetting new brackets, then welded them to my fork carriage. I almost built an adaptor to skid steer, then opted not to for the same reason. Now I have the blanks and extra 3/4" material to build anything else I need, although between the bucket and my forks, I don't think Ill need anything else.
   / Converting to skid steer attach on 20 series #6
Good solution I think, especially if you are fitting up just one more attachment like forks.
   / Converting to skid steer attach on 20 series #7
I had prematurely ordered a set of global/euro forks before my tractor was delivered, not knowing that the Branson quick attach was proprietary. I created a template and had these waterjetted. Came out great. I then cut off the brackets on the fork carriage I had, and welded these on.
   / Converting to skid steer attach on 20 series #8
We generally keep a couple sets of "Branson hooks" for just the same reason. It's a great system actually, but not universal unfortunately.
   / Converting to skid steer attach on 20 series #9
Hi Dave,
Do you still have any of the Branson Hooks that you would sell ?
Looking to build a set of forks.
Thanks
   / Converting to skid steer attach on 20 series #10
Hi Dave,
Thanks
I think everything we currently have on the shelf has been cut off of buckets when we converted same to SKC. So they are not flat on the back, they have a big notch where it wraps around the bottom of the bucket. We use them occasionally for the right application, but you would be better off to make a tracing of the bracket and go down to a metal place and have them cut you out a couple. With the right equipment, it is easy enough to do. We can burn you out a pair on our plasma table, but I doubt we would save you much if any after we have to ship them from the left coast to the right.
CAT 973 (A47384)
CAT 973 (A47384)
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2007 Toyota Tundra 4WD Pickup Truck (A53117)
2007 Toyota Tundra...
Syrup Kettle (A50123)
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A53473)
Texas Post Driver...
