converting side discharge finish mower to rear discharge
   / converting side discharge finish mower to rear discharge #1
Dan H
Has anyone ever tried this?
I have a Sitrex 5 foot side discharge finish mower and want to convert it to rear discharge.
Can I cut the baffles,( I guess that is what they are called) around the blades out and cut out the back and weld a piece over the side discharge hole? Will this work?
Thanks for any help.
   / converting side discharge finish mower to rear discharge #2
I can remember a couple threads about doing this. They may be in the attachments forum. I am not sure just what terms to use to do a search, if I find something that works I will repost but yes you are on the right track on converting.
   / converting side discharge finish mower to rear discharge #3
No but I converted a rear discharge ride-on mower deck to dual side/rear discharge.
A couple of things that may help you. I didn't dispose of the metal that I cut from the deck to make the new discharge chute. I cut it out but then I reattached it with hinges so it formed a flap that I could swing up when necessary. This also allowed me to easily revert back to the original configuration if necessary.
And my original deck had a pressed stiffening rib around the bottom. I did not want to reduce the strength of the deck too much so i did not cut through the rib. This means my new side chute has a horizontal rib near ground level. It has not been a problem. That may not be a practical option in your case.
I have no regrets about my 'experiment.'
   / converting side discharge finish mower to rear discharge #4
In attachments search "side discharge to rear discharge" . The banner will not permit me to do a forum search there. Just tried that search here and got a few hits that may help you.
Thanks for the info. I will have it done next week. I think it will work.
   / converting side discharge finish mower to rear discharge #6
Dan, How did you come out on this project? I want to do the same thing to my Befco mower.
2021 Toyota Corolla LE Sedan (A53424)
2021 Toyota...
Pair 2 - ST225/75R15 radial trailer (A53421)
Pair 2 -...
2013 Chevrolet Silverado 1500 (A55973)
2013 Chevrolet...
UNUSED JCT 84" HYD DOZER BLADE (A57193)
UNUSED JCT 84" HYD...
2009 BMW 3281 CONVERTABLE (A57192)
2009 BMW 3281...
UNUSED RAYTREE RMBD50 50" HYD DRUM MULCHER (A57193)
UNUSED RAYTREE...
