Converting Pneumatics to Hydraulics
   / Converting Pneumatics to Hydraulics #1
TexasSD
Parker County, Texas
Zennoh ~ L225
A buddy of mine is cleaning out a warehouse full of obsolete cabinet making equipment. In addition to a lot of steel that I am going to scavenge, the equipment has a bunch of pneumatic cylinders that he said I could have.
Some of my projects are going to require hydraulic cylinders, so in the spirit of recycling (and generally being cheap), I was wondering if these cylinders could be used as is or modified for hydraulic use.
Thanks for the help!
Scott
   / Converting Pneumatics to Hydraulics #2
the problem with the pneumatics is they arnt in the same force range as hydrolics.
avg hydrolic pressures are 1-2K psi.... avg pneumatic line pressure is 100-150PSI... or an order of magiatude less.
so what might be a 4000lb hyrolic ram is now a 400lb pn3eumatic ram... ie not good for much in the tractor world...
I thought the pressures would be the major issues, but was unsure how the differences in fluid dynamics between air and oil would affect the ram's performance.
Thanks for your reply!
   / Converting Pneumatics to Hydraulics #4
The fluid dynamics are the same, PSI applied to the surface area of the piston determines ram force. Unfortunatly, if you plumb them into a typical hydraulic system, they will burst as you will be exceeding their pressure rateing by nearly 10X:).
2020 Kubota SVL 75-2 Skid Steer (A51573)
2020 Kubota SVL...
2023 CATERPILLAR 299D3 XE SKID STEER (A51246)
2023 CATERPILLAR...
2018 FORD TRANSIT T150 CARGO VAN (A52577)
2018 FORD TRANSIT...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A53472)
2000 John Deere...
2018 JOHN DEERE 50G EXCAVATOR (A51246)
2018 JOHN DEERE...
2023 UNVERFERTH 632 LOT NUMBER 179 (A53084)
2023 UNVERFERTH...
