Ballast Converting old JD ballast box to I-match compatible
   / Converting old JD ballast box to I-match compatible #1
mscheer772
Hayward Wisconsin
4310 JD 2003
I have an old JD ballast box that will not fit the JD I-match. The middle top link arm on the box is not long enough(high enough). Does anyone know the length I need to make the box compatible and any idea on how to adapt it. I can't weld, at least not yet, so that's currently not an option. HELP!!!!!!!!!!!!
Thanks,
-Mike-
   / Converting old JD ballast box to I-match compatible #2
I think the center needs to be raised about 4", I know a friend of mine did it to his, but I don't recall the dimensions. Without a welder I'm not sure how your going to do it though...any chance you could take it to a welding shop?
Here are the proper dimension for the QH:
QH Specs
   / Converting old JD ballast box to I-match compatible #3
Without a welder. life is just a mess.....:(
you will haft to find a good fab shop....;)
Chris.....:)
Informational Lot - Shipping (A55315)
Informational Lot...
2022 JOHN DEERE 624P WHEEL LOADER (A52709)
2022 JOHN DEERE...
1998 INTERNATIONAL 9200 TANDEM AXLE DAY CAB (A57880)
1998 INTERNATIONAL...
2014 Mercedes GL550 AWD SUV (A56859)
2014 Mercedes...
Hr:2185.1 jihn Deere (A56857)
Hr:2185.1 jihn...
2018 Ford Fusion SE Hybrid Sedan (A56859)
2018 Ford Fusion...
