Ballast Converting old JD ballast box to I-match compatible
   / Converting old JD ballast box to I-match compatible #1
mscheer772
Hayward Wisconsin
4310 JD 2003
I have an old JD ballast box that will not fit the JD I-match. The middle top link arm on the box is not long enough(high enough). Does anyone know the length I need to make the box compatible and any idea on how to adapt it. I can't weld, at least not yet, so that's currently not an option. HELP!!!!!!!!!!!!
Thanks,
-Mike-
   / Converting old JD ballast box to I-match compatible #2
I think the center needs to be raised about 4", I know a friend of mine did it to his, but I don't recall the dimensions. Without a welder I'm not sure how your going to do it though...any chance you could take it to a welding shop?
Here are the proper dimension for the QH:
QH Specs
   / Converting old JD ballast box to I-match compatible #3
Without a welder. life is just a mess.....:(
you will haft to find a good fab shop....;)
Chris.....:)
Kinkaid 1200 LS-PH Towable Hydroseeder (A51691)
Kinkaid 1200 LS-PH...
2015 DODGE RAM...
McDon 75D Flex Draper Head (A52349)
McDon 75D Flex...
Ford NAA Jubilee Tractor (A52128)
Ford NAA Jubilee...
2016 Chevrolet Impala LT Limited Sedan (A48082)
2016 Chevrolet...
Heavy Duty Skid Steer Auger ECAG W/ 6", 12", and 14" Bits (A47384)
Heavy Duty Skid...
