Converting Hydraulic PTO driven implement to PTO
   / Converting Hydraulic PTO driven implement to PTO #1
pekabu
Platinum Member
NH
TC24D
I just purchased a snowblower that was driven by a hydraulic motor. The motor is no longer there. I would like to convert it to PTO use. It turns the right way. It is setup to take a 1" shaft with a key.
So, any suggestions on how I should do this?
   / Converting Hydraulic PTO driven implement to PTO #2
Did the hydraulic motor run the snowblower at 540 rpm? If it was much higher or lower, you could have a problem much greater than just hooking up the PTO. Have you checked with the manufacturer to see if they make a PTO direct driven model? If so, they might have all the parts you need. /forums/images/graemlins/cool.gif
Thanks, I am working that angle now. I don't believe they made a 3pt model.
   / Converting Hydraulic PTO driven implement to PTO #4
Find the rpm it was designed to run, then go from there. If that is is.. just get a pto shaft with the appropriate yoke.. shouldn't be too hard to find.
If it isn't the right speed.. you may be looking for a hyd motor and running it off a remote.. or off a pto powerd pump.. etc.
Soundguy
   / Converting Hydraulic PTO driven implement to PTO #5
If you have the aux hydraulics, the motor would probably be cheaper than the shaft and u-joints. Probably 50 of them on ebay right now 9.95 to 49.95. Hyd Surplus is another good spot too.
Guard Rail Joints (A51692)
Guard Rail Joints...
2014 Chevrolet Equinox 2LT SUV (A50324)
2014 Chevrolet...
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
2018 FORREST RIVER CRUISE LITE CAMPER (A52472)
2018 FORREST RIVER...
2021 KOMATSU D39PX-24 CRAWLER DOZER (A51246)
2021 KOMATSU...
2013 RAM 4500 (A50323)
