Converting Cat 2 implemnt to Cat 1 (Lower Lift Arm Pins)
   / Converting Cat 2 implemnt to Cat 1 (Lower Lift Arm Pins) #21
I think tractorpartsinc.com has the pin that will work for the needed application (1 1/8 thread to cat 1 pin). The part number is HII20-0034 I just ordered 2 for about $24 with shipping and I will follow up if they don't work.
Here is a snip of it for future reference:
   / Converting Cat 2 implemnt to Cat 1 (Lower Lift Arm Pins) #22
I'm hoping that picture isn't accurate because the threads should be noticeably bigger than the pin. I'll take a picture of what I get on Friday and post it on here.
   / Converting Cat 2 implemnt to Cat 1 (Lower Lift Arm Pins) #23
I can verify that this part worked like a charm. Cat 2 thread with a Cat 1 pin. Quick shipping too. Here is a picture.
By the way, it took an 1-5/8 socket to turn the cat 2 nuts, an impact wrench, some pb blaster, a screwdriver to hold the pin while turning the bolt, a 3/4 drive pull bar to turn the socket when the impact wrench wouldn't turn it, and a pipe wrench to hold the pin after the screwdriver snapped in two:)
   / Converting Cat 2 implemnt to Cat 1 (Lower Lift Arm Pins) #24
Thanks for the update. :thumbsup:
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
BUSH HOG 7007 LOT IDENTIFIER 103 (A53084)
BUSH HOG 7007 LOT...
(2) 330 GALLON POLY TOTES (A51248)
(2) 330 GALLON...
2012 JOHN DEERE 10-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53472)
2012 JOHN DEERE...
