Converting AWS
   / Converting AWS #1
FarmerGene
Case D29
If I wanted to convert my 425 aws to what would act as a solid axle, would I just be able to disconnect the linkage and make some type of brackets to bolt it up solid? possibly to the axle with heavy muffler clamps? also, would I then be able to put 26" tires on with a 54" deck? I'm doing this because of the added benifits of the larger tires. I only have two trees i have to mow around so i'm not worried about losing the aws feature. thanks
   / Converting AWS #2
Sell it and buy one that has straight steering.
Seems like a lot of hassle to go through to disable the rear wheel steer.
I like the benefits of the AWS so much I wouldn't buy a lawn tractor without. Mowing on sidehills is so much better with AWS, as is getting out of a pinch when a wheel loses traction.
But to each their own. :)
Be interested in how you accomplish that feat.
2006 Volkswagen Jetta Sedan (A50324)
2006 Volkswagen...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
PALLET OF SINGLE & DOUBLE SINKS (A51244)
PALLET OF SINGLE &...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50774)
STOP!!!! PLEASE...
