Converting a sickle bar mower to a hedge trimmer
   / Converting a sickle bar mower to a hedge trimmer #1
binna
Nortrac 25XT
Hello Everyone
Has anyone ever converted an old Dearborn mower into a Hedge trimmer? It all works but I want to mount a hydraulic motor similar to to the Samari made by Cutthroat, I would need a slow hi torque motor and a gear of some sort to run the blade. Any Ideas or is some one has a used Samari hedge trimmer.
   / Converting a sickle bar mower to a hedge trimmer #2
Old dearborn not made for brush. Don't do it. It "might" work for very small twigs, but will likely become clogged/plugged quickly even if it does work. Notice dual tooth sliders on the Samurai vs single tooth bar on dearborn......
   / Converting a sickle bar mower to a hedge trimmer #3
I don't about the old Dearborn but,
the Ford 501? will cut up to an inch in diameter with sharp knives and guards quite easily.
I have also considered doing something similar but I wouldn't use anything with a pitman arm,
I would want a mower with a wobble box drive. I'd run a belt from the hydraulic drive to the
mower pulley as a slip clutch.
Thanks for the replies, I guess best bet is to try and find a used one as the new price is 1170-1895 a little pricey I think
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
2006 Mack CV713 Granite Tri-Axle Roll-Off Truck (A48081)
2006 Mack CV713...
2015 CAT 573c Fellerbuncher Cutter (A48836)
2015 CAT 573c...
2025 20ft. G70 Cargo Transport Chain (A48081)
2025 20ft. G70...
2008 Ford Crown Victoria Sedan (A48082)
2008 Ford Crown...
1271 (A50490)
1271 (A50490)
