CONVERTING A HAYFIELD INTO A SMOOTH LAWN
   / CONVERTING A HAYFIELD INTO A SMOOTH LAWN #1
VOL54
NW Tennessee
New Holland TC45DA, John Deere 345
I am in the process of trying to convert 7 acres of former hayfield to a smooth lawn. Field is a mixture of all sorts of tough grasses and weeds which, in combination with rough ground, is making it difficult to mow with my tractor and new finishing mower. Does anyone have any ideas on how to level the ground to make it easier and faster to mow? I am trying to avoid the expense of having to break the soil and replant new grass. Thanks.
   / CONVERTING A HAYFIELD INTO A SMOOTH LAWN #2
The lawn is the 1/4 acre around the house. The rest is a hay field. Grow hay. :)
Or spend about 3 days a week mowing your lawn. :(
Bruce
   / CONVERTING A HAYFIELD INTO A SMOOTH LAWN #3
That's a pretty tall order. I'm interested to see if anyone has an idea for that.
This property has been a hayfield for thirty + years. I just invested in a tractor and 7.5ft finishing mower. I want it to be a huge lawn. I'm retired and it won't take but a few hours to mow if I can get my speed up. But it's got to be smoother to do accomplish that.
   / CONVERTING A HAYFIELD INTO A SMOOTH LAWN #5
I've been gradually turning an old cornfield into lawn. I found what worked best for me was to knock down the high spots with a box blade, disk everything under, rake it out to remove the rocks, cornstalks, weeds, etc...and seed heavily. The first year was disappointing as it appeared nothing but weeds were growing. Year 2, the grass is overtaking the weeds and next spring I should be able to take care of the rest with some weed and feed product.
   / CONVERTING A HAYFIELD INTO A SMOOTH LAWN #6
Wait till spring when the grounds soft and roll it over and over in multiple directions. You'll probably have to repeat each spring.
   / CONVERTING A HAYFIELD INTO A SMOOTH LAWN #7
Here are three LINKS to the T-B-N archive relevant to your topic, which is regularly debated here:
LINKS:
https://www.google.com/search?clien...tractorbynet.com&ie=UTF-8&oe=UTF-8&gws_rd=ssl (1,000+ threads)
https://www.google.com/search?clien...tractorbynet.com&ie=UTF-8&oe=UTF-8&gws_rd=ssl (200+ threads)
https://www.google.com/search?clien...tractorbynet.com&ie=UTF-8&oe=UTF-8&gws_rd=ssl (1,400+ threads)
How much rock do you have in your soil?
Tennessee conditions very from loam to almost all rocks.
If you have loam or moderate rocks a Harley Rake is your best implement for smoothing seven acres.
LINK:
Search Results - Harley Rake TractorByNet.com
2020 Isuzu NPR Heil 8RLDB 8CuYd Rear Loader Garbage Truck (A52377)
2020 Isuzu NPR...
205028 (A52706)
205028 (A52706)
Rubbermaid Water Trough - 100 Gallons (A55218)
Rubbermaid Water...
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
UNUSED LANDHERO LDH-T460 STAND ON SKID STEER (A54756)
UNUSED LANDHERO...
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
