Converting a Gas Chipper to PTO Driven??
   / Converting a Gas Chipper to PTO Driven?? #1
Farm.E.R
I own an ancient "Roto-Hoe" gas powered chipper shredder. It is belt-driven, powered by a 5 hp Briggs & Stratton. The engine would need to be over-hauled completely or replaced.
Since, I now own a tractor (NH TC30)... it there a "bolt-on" transmission that could mount to the PTO, with a pulley, that I could use to "belt up" to the chipper or other home-made implements?
thanks,
farm.E.R.
   / Converting a Gas Chipper to PTO Driven?? #2
What's the operating rpm of that gasser? 3600rpm?
if so, sounds like near 6:1
soundguy
   / Converting a Gas Chipper to PTO Driven?? #3
Keep the belt drive to dampen vibrations. What are the pulley diameters and in what order are they mounted ? i suppose small pulley driving the big pulley ?
If so, you could reverse the pulleys and speed up the drive. That would allmost be enough, so you could use a 1:1 gearbox, or just bolt a splined PTO end to the pulley shaft.
I am very new to tractors. (about 3 weeks) Its parked in my garage, here in Las Vegas. I have been accumulating "stuff" from craigslist
for a farm that I want to build in Green River, Utah. I just got my water rights!
I have a lot to learn about tractors. I did some searches on gear boxes... how cool.
Someone painted-over everything on the chipper... so I'll do some research on the rpm's... then figure out the correct ratios for the pulley dimensions.
I have a lifetime of projects ahead.
Thanks!
farmER
You get some interesting looks, when you drive a tractor on the streets of Las Vegas... everybody thinks your in a parade.
   / Converting a Gas Chipper to PTO Driven?? #5
And I'll bet that a tractor with a chipper on the back makes them think your cleaning up a mob hit a-la "Fargo".
jb
No Comment....forgetaboutit!
   / Converting a Gas Chipper to PTO Driven?? #7
Since I'm originally from Brooklyn, NY, I can tell you that it's
FUGGEDABOUDIT.
   / Converting a Gas Chipper to PTO Driven?? #8
thanks,
farm.E.R.
I believe I have the identical chipper which I have been considering doing the same conversion (but I'm building a trailer at the moment, and for political reasons that most married men will understand, the chipper will have to wait till another day)
However, I'm thinking that (without removing the belt cover) the pulley sizes might be about 1:3, which would mean the main chipper shaft would be somewhere in the 700-1000 rpm vicinity. If that is the case, I'm thinking PTO shaft with a slip clutch (or shear pin) directly to the chipper shaft.
This would of course still be a very light duty chipper, but it would mean one less engine to fool with three or four times a year when dealing with the annual yard waste and prunings.
We now live in a no-burn area :(
Keep us posted with what you've got going.
Regards
Sherweld
   / Converting a Gas Chipper to PTO Driven?? #9
thanks,
farm.E.R.
Hey FarmER, My 2 cents: I would think that the chipper is not going to be worth your time to mount to the TC30. If a 5hp engine can handle that chipper, your TC30 is going to burn to much fuel for the amount of work that you will be able to produce. If you really have some chipping to do, you might want to investigate the PTO units made by Troy or some other mfg.
The fuel issue is a good point... but since I need to replace the motor anyway, I was thinking about doing the conversion. I have only owned a tractor for a few weeks, so the conversion might be a good exercise for me.
I'm currently a shirt & tie man... so the thought of getting greasy fingers is very exciting.
I think the shredder is 2800 - 3600 rpm... did someone say belt-cover...NOT. My model was the widow-maker... they couldn't make this unit now. Small people and children could easily become "mulched".
I will take a look at it again ... I like Sherweld's thoughts on the direct drive with the slip clutch... but maybe too much vibration... also might be beyond my skills to get a proper ratio.
I appreciate your comments.... fuggedaboutit! (I spent too much time in the burbs)
farm.E.R.
   / Converting a Gas Chipper to PTO Driven?? #11
farm.E.R.
If that sort of thing gets the juces flowing.. then i'd suggest buying an antique tractor or a chinese tractor.. both require a bit of hands on 'greasy finger' kinda touching to keep them running... of course.. you figure the antique needs it since it's decades old... and i guess the excuse for the chinese is it's cheap.. er.. inexpensive.. ;)
soundguy
   / Converting a Gas Chipper to PTO Driven?? #12
A TC 30 will probaboly run it at 1200 engine RPM which will burn less fuel than a 5hp gasser, if you have the proper transmission ratio.
   / Converting a Gas Chipper to PTO Driven?? #13
I came across 2 units this spring just like you mentioned. The owner of the lot I was cleaning up tols me I could have one if I could help get his on the back of his tractor. I had an old 12 inch pulley and shaft from a combine and I put a set of pillow block bearings on it. Then on the end of the shaft I adapted a universal off a pto shaft to his tractor. There was an old 3 point carry all there and we mounted the chipper there. It really hums about 2 inches soft wood and 1.5 on hard wood limbs. The tractor just idles and hums along. The set up isnt quite clean as I like but it suits him. The previous owner left them there as the engines were too much to keep up for 2 or 3 times a year useage. Mark has used his to chip shrubs and such around his over grown place. I ve moved about 10 yards of chips from his machine. Im wanting to try to get to mine togeth this month.
Well... I ended up buying an edger with a B&S engine at a flea market for $25 and swapped the engine into the chipper. It was too easy & too cheap to pass up.
My next hair-brained idea... pto powered grain mill (for domestic use).
KUBOTA SSV65 OPEN STATION CAB (A52706)
KUBOTA SSV65 OPEN...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
UNUSED FUTURE EQUIPMENT SEAT (A60432)
UNUSED FUTURE...
PALLET OF 15 4 X 8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4 X 8...
2008 TCE MANUFACTURING 20GN GOOSENECK GEN TRAILER (A58214)
2008 TCE...
2021 Harley-Davidson FLHP Road King Motorcycle (A59231)
2021...
