Converting a Gas Chipper to PTO Driven??
   / Converting a Gas Chipper to PTO Driven?? #11
I'm currently a shirt & tie man... so the thought of getting greasy fingers is very exciting.
farm.E.R.
If that sort of thing gets the juces flowing.. then i'd suggest buying an antique tractor or a chinese tractor.. both require a bit of hands on 'greasy finger' kinda touching to keep them running... of course.. you figure the antique needs it since it's decades old... and i guess the excuse for the chinese is it's cheap.. er.. inexpensive.. ;)
soundguy
   / Converting a Gas Chipper to PTO Driven?? #12
The fuel issue is a good point...
A TC 30 will probaboly run it at 1200 engine RPM which will burn less fuel than a 5hp gasser, if you have the proper transmission ratio.
   / Converting a Gas Chipper to PTO Driven?? #13
I came across 2 units this spring just like you mentioned. The owner of the lot I was cleaning up tols me I could have one if I could help get his on the back of his tractor. I had an old 12 inch pulley and shaft from a combine and I put a set of pillow block bearings on it. Then on the end of the shaft I adapted a universal off a pto shaft to his tractor. There was an old 3 point carry all there and we mounted the chipper there. It really hums about 2 inches soft wood and 1.5 on hard wood limbs. The tractor just idles and hums along. The set up isnt quite clean as I like but it suits him. The previous owner left them there as the engines were too much to keep up for 2 or 3 times a year useage. Mark has used his to chip shrubs and such around his over grown place. I ve moved about 10 yards of chips from his machine. Im wanting to try to get to mine togeth this month.
Well... I ended up buying an edger with a B&S engine at a flea market for $25 and swapped the engine into the chipper. It was too easy & too cheap to pass up.
My next hair-brained idea... pto powered grain mill (for domestic use).
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
2019 CATERPILLAR 305E2 CR EXCAVATOR (A52709)
2019 CATERPILLAR...
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
(INOP) 2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
(INOP) 2015 FORD...
SKID STEER ATTACHMENT GRUBBING BUCKET (A58214)
SKID STEER...
2 Warehouse Forks (A55787)
2 Warehouse Forks...
