Converting a batwing to a single fold
/ Converting a batwing to a single fold #1
minner
Arab, AL
Kubota M7040 cab
I have been toying with the idea of getting a Bush Hog 2615 and basically converting it to a 2610. I have a few maintenance jobs where a 15' batwing would be easy for my M7040 but there are other annual jobs that a 15 footer would be too much. Used 10 footers usually bring as much or more than a 15 footer so buying two is out of the question and settling for a 2610 would be selling myself short. Ideally I would fabricate a counter weight and be able to go back and forth as needed.
Before your mind starts to wander, no I can't mow with one wing up (residential areas) and no I don稚 want a rigid deck.
/ Converting a batwing to a single fold #2
I've been around a couple of 2610's and they look like a good idea but aren't. They suck on slopes, the counterweight is always dragging the ground, and they just don't trail correctly. As far as dropping a wing from a 2615 more than once in its lifetime, count me out. It's not a job you are likely to want to do twice.
Can you enlighten me on the counterweight dragging and why they don't trail right (assuming flat ground)?
/ Converting a batwing to a single fold #4
The counterweight doesn't consistently offset the drag produced by the wheels and skids of the wing. It's just not the same as having a wing of equal weight, size and with the same number of wheels on either side of the machine. If a 15 foot machine is "too much for some jobs" a 2610 wannabe won't be significantly more manuverable than a 2615, but it will cut less.
/ Converting a batwing to a single fold #5
You probably could just unhook the driveshaft from the front gearbox on the one side, then fold the one wing up, and lock it into place (wouldn't work good on slopes either, but would be kind of ok on flat ground). Plus no ground dragging counter weight, when you need 15' fold it back down, hook the driveshaft back up, and go.
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2018 Ford Fusion Hybrid Sedan (A64557)
2018 Ford Fusion...
Sunflower 1234 (A64126)
Sunflower 1234...
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
New/Unused Wolverine Quick Attach 72in Grapple Bucket (A65583)
New/Unused...
New/Unused Heavy Duty Plate Compactor (A65583)
New/Unused Heavy...
