Convert valve to self-canceling detent
/ Convert valve to self-canceling detent #1
mtncur
Grand Rivers, Kentucky
John Deere 5083e, Kubota L3240
I have a JD 5083e which has 2 rear remotes both with non-detent valves. I need one of the valves to be self canceling detent for operating a round baler tailgate. Can one of these valves be converted or do i have to just replace the valve?
/ Convert valve to self-canceling detent #2
Creating a detent action is purely mechanical, but you'd still need a different spool (longer on the ends) and then be able to add detent ends on the valve body. If it's a simple valve, likely that it doesn't have provisions to add different ends to the block even if you could locate and swap a new spool in.
Self-canceling is a combination of mechanical and hydraulic action, and I know that definitely couldn't be converted. The valve would have to be plumbed different internally --- needs a feedback loop and ports to create the canceling action --- so I doubt very much if you could convert an existing valve. There would have to be a lot of extra machining inside the block for the self-canceling action and/or ports for an external feedback loop.
Given the complexity to all of this, I doubt any manufacturer makes valves to be converted on both fronts. They likely just sell different models with all the specifics worked out unique to the valve block and spool used.
Enclosed Trailer with Lube System (A62613)
Enclosed Trailer...
2006 Cadillac Superior 6-Door Limousine, Ultra-Low 20396 Miles (A63689)
2006 Cadillac...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
5' Bush Hog Mowing Deck (A62613)
5' Bush Hog Mowing...
FORD 5610 TRACTOR (A64276)
FORD 5610 TRACTOR...
2016 KENWORTH T880 T/A DAY CAB ROAD TRACTOR (A64276)
2016 KENWORTH T880...
