Convert tow behind aerator to 3pt hitch.
   / Convert tow behind aerator to 3pt hitch. #1
doneill127
CT
Mahindra Max
Few years ago rented a 3pt aerator but found to be too much of a pain between the cost, and 45min trip each way, loading unloading from the landscape trailer. So decided I could buy a little bit smaller tow behind for almost the price of the rental. Ended up with a 48” Agrifab. Well that didnt turn out to well either. I have a lot of walkways, small access areas gravel and paved driveway so had to constantly get on and off to raise it up. So decided to convert it to a 3 pt hitch set up. Did about an acre today and nothing failed though many of the welds are kind of ugly. Have another acre to knock off tomorrow. It’s totally bolt on, and can be converted back to a tow behind without any problem.
IMG_3779 Medium.jpegIMG_3777 Medium.jpegIMG_3787 Medium.jpegIMG_3791 Medium.jpeg
Thanks. Aside from wanting the 3 pt set up also wanted brush up on my welding. Want to restart restoration project of a 1956 oval beetle that’s disassembled in the barn.
   / Convert tow behind aerator to 3pt hitch. #4
Looks good. Did you have to add any ballast when in use, or is it heavy enough as-is?
I need at least 4 cinder blocks to get the tines to penetrate the soil. When it was towed, the wheels had a hard time handling that and raising and lowering it was a pain. To stiffen things up, the frame is 2x2x1/8 angle, and I used 1x1x1/8 to connect them.
Rev 01
The flat bar stock tie between the upper link channels and the rear angle has bowed. I used that because I saw someone else had done something similar and assumed it would only be in tension. Guess I was wrong. I’ll have to add a stiffener to it.
   / Convert tow behind aerator to 3pt hitch. #7
Rev 01
It is going to either need to be really strong to resist bending, or the top link will need to be a pivoting connection with that angled support made out of something flexible like chain. Pull up a picture of a box blade and look at the structure of the A-frame, pretty hefty.
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
(4) 225/65R17 USED TIRES (A58374)
(4) 225/65R17 USED...
2021 Chevrolet Silverado 2500HD 4x4 Crew Cab Pickup Truck (A56858)
2021 Chevrolet...
20ft x 30ft Steel Carport (New/Unused) (A59225)
20ft x 30ft Steel...
2014 FOREST RIVER WILDWOOD RV TRAILER (A58214)
2014 FOREST RIVER...
