Convert single acting tractor hydraulics to double acting
   / Convert single acting tractor hydraulics to double acting #1
kplew
East Wallingford
Intentional B414
Folks- I have a 63 International B414 with a single remote hydraulic connector. I would like to pull a haybine with a double acting cylinder. Is there any type of valve or setup that would let me do this?
Thanks for your help
Kevin
   / Convert single acting tractor hydraulics to double acting #3
Kplew,
Converting the cylinder would probably be easier. I suspect you would have to replace the complete valve body and i also suspect this would be difficult.
   / Convert single acting tractor hydraulics to double acting #4
Kevin
The answer is, yes you can, but is it worth it in terms of money.
You can add a DA valve and DA cyl and do what you want.
Surplus Center - 1 SPOOL 8 GPM PRINCE MB11B5C1 DA VALVE
Look in the cyl section for the bore size, rod size, and the stroke.
http://www.surpluscenter.com/sort.asp?keyword=HCD2&catname=hydraulic&PAGELEN=20&PageNo=3
You could add a two spool valve for other functions you might need in the future.
1985 Miller Wildcat 350-D Welder (A51691)
1985 Miller...
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A51406)
2007 FORD F750 XLT...
2022 Polaris Ranger 4x4 Utility Cart (A54811)
2022 Polaris...
Tennant 800 Ride-On Street Sweeper (A53421)
Tennant 800...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
