Convert new holland 555e backhoe from 2WD to 4WD
   / Convert new holland 555e backhoe from 2WD to 4WD #1
ALANANDERSON
Trevose, Pa
Newholland 555e
Gentleman,
I would like to convert a 97 Newholland 555e shuttle shift backhoe from 2WD to 4WD. Based on the part numbers that are common, it appears that a 4WD trans and axle will fit into the machine. The bell housing is the same, as is the torque conv to flywheel mounting plate. Also rear driveshaft is the same, and the trans mount. I have found a trans and front axle with tires and rims. The only concern are that the rear axle ratio works with the new front axle, and I need to change the electrical system to add a 4WD engagement solonoid. Since I have limited resources avaliable regarding this change, does anyone have any thoughts on doing this project?
   / Convert new holland 555e backhoe from 2WD to 4WD #2
More work than I'd sign up for on a machine of that age. If you are worried about axle ratios, consult the parts catalog & see how many choices there are.
   / Convert new holland 555e backhoe from 2WD to 4WD #3
Sell it and buy a 4wd. Wiser in the long run.
   / Convert new holland 555e backhoe from 2WD to 4WD #4
I agree, too many things to go wrong with that conversion. Swap out the tractor for a 4WD model.
   / Convert new holland 555e backhoe from 2WD to 4WD #5
I agree, check ratios available from parts catalog. I doubt there were many, if any options, but check first.
2019 KENWORTH T680 SLEEPER TRUCK (A52141)
2019 KENWORTH T680...
Chery 10' 18 Drawer Workbench (A50121)
Chery 10' 18...
Chery 6' 10 Drawer Workbench (A50121)
Chery 6' 10 Drawer...
2008 BMW 535xi AWD Sedan (A50324)
2008 BMW 535xi AWD...
2020 Caterpillar 420F2 4x4 Loader Backhoe (A50322)
2020 Caterpillar...
