Convert new holland 555e backhoe from 2WD to 4WD
   / Convert new holland 555e backhoe from 2WD to 4WD #1
ALANANDERSON
Trevose, Pa
Newholland 555e
Gentleman,
I would like to convert a 97 Newholland 555e shuttle shift backhoe from 2WD to 4WD. Based on the part numbers that are common, it appears that a 4WD trans and axle will fit into the machine. The bell housing is the same, as is the torque conv to flywheel mounting plate. Also rear driveshaft is the same, and the trans mount. I have found a trans and front axle with tires and rims. The only concern are that the rear axle ratio works with the new front axle, and I need to change the electrical system to add a 4WD engagement solonoid. Since I have limited resources avaliable regarding this change, does anyone have any thoughts on doing this project?
   / Convert new holland 555e backhoe from 2WD to 4WD #2
More work than I'd sign up for on a machine of that age. If you are worried about axle ratios, consult the parts catalog & see how many choices there are.
   / Convert new holland 555e backhoe from 2WD to 4WD #3
Sell it and buy a 4wd. Wiser in the long run.
   / Convert new holland 555e backhoe from 2WD to 4WD #4
I agree, too many things to go wrong with that conversion. Swap out the tractor for a 4WD model.
   / Convert new holland 555e backhoe from 2WD to 4WD #5
I agree, check ratios available from parts catalog. I doubt there were many, if any options, but check first.
2014 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55973)
2014 Chevrolet...
2016 Isuzu NPR Landscape Dump Truck (A56858)
2016 Isuzu NPR...
MURRAY PUSH MOWER (A55745)
MURRAY PUSH MOWER...
2017 FORD F350 CREW CAB 4X4 PICKUP TRUCK (A56138)
2017 FORD F350...
UNUSED FUTURE FT-RP72 - 72" HYD ROCK CRUSHER (A52706)
UNUSED FUTURE...
BAT WING SHREDDER (A58214)
BAT WING SHREDDER...
