convert a backblade to landscape rake on BX
   / convert a backblade to landscape rake on BX #11
............... Anyone have the single hole tines? Happy with them?
If the single hole tines are mounted with spacers between them, they will never rotate. Below are pic's of the system I used to mount mine. I used one hole tines and are very happy with them, they also use 1/2 the mounting hardware and the way it was done does not require any holes to be drilled.
Larry
   / convert a backblade to landscape rake on BX #12
Half the hardware but, double the ammount of steel. I think the way you mounted them is really sturdy thou. Nothing wrong with a little over engineering.
Since I will be using a I beam, I was thinking if i use a 2 hole tines, I would put a bolt on each side of thebottom of the I. (makes sense ?) My welds is not pretty and something is not working on my EZ hobart welder right now. Not sure whats wrong with it. Ground clamp is ok, The wire feed is coming out ok, just no spark power at end of wire, its like the ground is dead.
2015 Ford F-450 Crew Cab Knapheide Service Truck (A53422)
2015 Ford F-450...
1067 (A53342)
1067 (A53342)
UNUSED FUTURE MINI EXCAVATOR HYD WOOD DRILL (A57193)
UNUSED FUTURE MINI...
UNUSED FUTURE FT-ZP20 20' X 30' GARAGE CARPORT (A57193)
UNUSED FUTURE...
UNUSED FUTURE 32"...
utv cart Honda (A56857)
utv cart Honda...
