Convert 3ph on TU155 to double-acting hyd?
   / Convert 3ph on TU155 to double-acting hyd? #1
Chris_in_Oz
South of Perth, Western Australia
Iseki TU155 Landhope
Is it possible to modify the 3ph to be able to hydraulically lower (ie under power, instead of gravity)?
With a post hole borer it can be difficult to get it started and I would like to be able to give it a push.
Is it possible/reasonable/affordable?
If not, I could add weights, but this seems less than ideal.
Cheers,
Chris.
Cheers,
Chris.
   / Convert 3ph on TU155 to double-acting hyd? #3
None of these cmall tractors have power down. They are so light it really wouldn't do much. In your case it would help, but if you were moving it would just raise the wheels off the ground.
   / Convert 3ph on TU155 to double-acting hyd? #4
Hey, Kayssupply! Always good to know knowledgeable people like you are out there.
Hadn't thought about using power down while towing an implement, but it makes a lot of sense. Although I wouldn't want it to run me over, it isn't very heavy and I can see the wheels would be easy to lift.
Going back to my original question - Is power down possible?
Where is the ram for this? The tilt L/R ram is obvious, but not the lift???
Also, while talking about the tilt L/R ram, what is the "little ram" piggy-backing it? It has no hydraulic pipes, only electrical and it moves in and out with the the tilt L/R ram. Is this a position sensor for the "auto till" feature? Or something else?
Cheers,
Chris.
Cheers,
Chris.
   / Convert 3ph on TU155 to double-acting hyd? #7
If the little one has wires going to it, it is a posistion sensor used by the computer for the tiller. They say the computer does not work on most of these used tractors.
   / Convert 3ph on TU155 to double-acting hyd? #8
   / Convert 3ph on TU155 to double-acting hyd? #9
I have only had one that the electronic controls worked. All have worked manual but just one auto. I really don't think power down is an option the way the piston is built. It is under your seat inside the top housing. I don't think there is a tapping you can put pressure to. It just releases pressure back into the sump.
   / Convert 3ph on TU155 to double-acting hyd? #10
2010 Chevrolet Equinox SUV (A51694)
2010 Chevrolet...
2012 VANGUARD 53FT DRY VAN TRAILER (A52576)
2012 VANGUARD 53FT...
2005 IH 7600 t/a Dump Truck (A52384)
2005 IH 7600 t/a...
1994 Prevost Liberty Coach Motorhome (A51694)
1994 Prevost...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
2005 Sterling Acterra Tender Truck (A52748)
2005 Sterling...
