Conversion of CAB lights to LED
   / Conversion of CAB lights to LED #1
mownby49
Kioti DK5310se HST CAB
2022 Kioti DK5310 HST CAB
I want to change the OEM CAB lights to LED. Is there an LED seal beam replacement or just the bulb replacement?? Please advise recommendation or info for LED conversion. Thank you.
   / Conversion of CAB lights to LED #2
maybe here…
   / Conversion of CAB lights to LED #3
i found i could not simply change the lamp, i had to change the fixture. there super bright though. i had to lift the roof to do it. the last two pics show lights before then after. major change
   / Conversion of CAB lights to LED #4
Thanks for adding. I just went and looked at my new DK5310SE HST cab today. Get to pick up tomorrow or Wednesday this week after they fill the tires, add the radio and 3rd function. We will soon see what all needs to be upgraded 😁
   / Conversion of CAB lights to LED #5
i have no idea if current light fixtures were like to older (mines a 2010 era) halogen lights, but back when i switched mine out the halogen replacement led lamp wasnt much brighter than the halogen. so i went with 4 x CREE led fixtures.i installed them in 2016, no issues and there used alot all winter moving snow.
   / Conversion of CAB lights to LED #6
Me either, mine has two on the windshield pillars and 2 on the cab front. Ive ordered some led replacements from superbright leds for trucks and trailers and had reasonably good luck.
You probably do more night time work plowing, can you ā€œseeā€ the bucket in the dark when its snowing with the cab lights? I put a lightbar on my skidsteer and that can be too bright sometimes (passing cars, loading trucks if you hit the mirrors just right).
   / Conversion of CAB lights to LED #7
can see quite far in winter snow blowing....very bright. i have to kill upper lights if driving on road in oncomming traffic.
heres a pic from last winter blowing snow.
   / Conversion of CAB lights to LED #8
I have always been disappointed when replacing individual bulbs with led bulbs. The white lights never seemed to reflect properly in the original halogen housing. Flashers and running light LEDs are great in the OEM housings though.
I replaced the halogen housings with 55w 9" combo flood / spots on the front and rear of my cab 6 years ago. They practically turn night into day. I do most of my snowplowing at o'dark thirty, and the LEDs make the job much easier. I also turn them off on the road, as they are blinding to other vehicles.
   / Conversion of CAB lights to LED #9
rj, your attachment didnt work
   / Conversion of CAB lights to LED #10
My only comment is buy new LED lamps, preferably with CRE SMD's On the Kubota in my signature picture, I have 4 forward facing LED long throw spot lamps and 2 wide angle lamps facing back and I can see at least 1/2 mile with the 4 in the front and they draw less amperage than the OEM halogens did. I got them from Superbright LEDs. and they have worked flawlessly for a couple years now. I guarantee if you turn them on and someone is coming toward you, you will roast their eyeballs. I also replaced the filament bulbs in the grill headlights with LED bulbs and every other light on the tractor as well.
2012 DOOSAN G25 GENERATOR (A53843)
2012 DOOSAN G25...
2019 FORD TRANSIT VAN (A52576)
2019 FORD TRANSIT...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
Metal Peacock Lawn Art (A55853)
Metal Peacock Lawn...
2015 CATERPILLAR D5K2 LGP CRAWLER DOZER (A52707)
2015 CATERPILLAR...
19015 (A55788)
19015 (A55788)
