Conversion Factor for 3PH load capacity
/ Conversion Factor for 3PH load capacity #81
If the specs were 2000lbs at 1 ft then 1000 at 2 ft or again 500 at 4 ft.
The math is not all that difficult.
You convert to foot pounds; 2000 X 1ft= 2000 ft lbs
If load is then at 3 ft, 2000/3=666.6 lbs.@ 3ft.
The lift arms are 38" long at their ball centers. The lift link operates in their middle [19"]. Lift at the ball ends is 1700#. What is the lift at 9 feet out from the balls?
/ Conversion Factor for 3PH load capacity #82
SPYDERLK & LD1 - More power to you! I would not have the patience to explain this over and over and over and over and over and over... Hey, can we talk about self leveling loaders next :D
Oh, and I'm glad you resurrected this. It was the most entertaining thread that I read all night! :D
/ Conversion Factor for 3PH load capacity #83
;) Mechanical self leveling will lift more with the same hyd force than will a non leveling loader.
/ Conversion Factor for 3PH load capacity #84
You gave the length of the lower lift links (You called them arms, that is easily understood, but is also immaterial) but not the length of the lifting arms, nor the maximum capacity if the lifting arms.
NB The force is presented by the lifting arms, the lower 3ph members are lifting links, they can apply no force, only shift it's point of application.
If the lifting arms are 19 inches long, they must generate 2X the lifting force as the carried by the 38 inch long lifting links or 3400# which is 64600 pound inches
At 108 inch distance leverage, this would give a max lifting capacity of about 600 pounds.
"give me a lever long enough, and I shall move the earth"
/ Conversion Factor for 3PH load capacity #85
5 1/2, nearly 6 years later....
Do you REALLY think anyone still CARES about this ?
... And, in that period, Progress integrated over Time has taken a big swerve toward Zero
/ Conversion Factor for 3PH load capacity #86
So you apparently still dont know what Ive said. You continue to throw argument into the mix while making re statements of virtually identical descriptions I have made and original misstatements of things you falsely attribute to my statements. The limit to the load is the force at the eyes. The limit to how far back that load can be is the back tipping point of the tractor. Nothing will break unless you add front weight to keep the tractor from tipping - - or maybe drive around over bumps while teetering back and forth. Most people would catch that indication and call it a clue.
larry
Well, I just reread this lengthy thread and have discovered for myself where the "cognitive disorder" has manifest.
Spyderlk is using the fixed "tipping" of the tractor as the limiting condition. No front weights, no loader filled with gravel etc. I'm not sure why, as this is never part of any tractor specification I have heard of, and I know that makers don't "uprate" the 3ph lifting capacity when some type of front ballast is present.
This is the clue for the clueless that Larry has been talking about. ;-)
A second "disorder in thinking" is in regards to the perfect parallelogram logic. Yes, there are some interesting effects in a four bar link, but the most important one is that without some load bearing support, such as triangulation or an ADDITIONAL SUPPORTING MEMBER. a parallel motion linkage will just lay flat on the ground. Lifting nothing.
So that returns the logic back to answer the question of what does do the lifting, and what are the limitations. Manufacturers state limits for a reason, and it's not because they cant find equal length top and bottom links.
For me it gets back to one of the very first responses that brings up the moment arm concept. and for my experience, I have never seen a tractor 3ph that did not make use of lifting arms rotating on a rock shaft.
So yes, one can make a parallel motion linkage that will translate any load to it's end pins. And if those end pins are the element calculated for failure at the rated lifting capacity. There will be the case proposed by Larry.
But, If the 3ph lifting capability is limited by hydraulic pressure on the 3ph actuating cylinder(s), along with the lifting arm length (leverage. moment, torque, call it what you will) Then we have the situation on 99.99% of all tractors being discussed on these forums, and the load ratings can be compared with simple proportional math. Simple levers. What the makers should be posting IN ADDITION to lift rating is "maximum lifting force at the lift arm ends", and for those machines that offer hydraulic down pressure, negative values as well ;-)
PS , the balance scale example was used exactly in REVERSE of the required purpose, for the sliding weights (the lifted load) moves along the scale beam. Think about it, which end is being "lifted?
Also, in regard to "lifting the boom pole" from various distances. Again backwards example. What would the lifting arms and hydraulic cylinder be experiencing in each case?
Shared perspective is so difficult, but comparing lifting performance of tractor three point hitches is not so hard once the details are considered.
/ Conversion Factor for 3PH load capacity #87
No, I think. What I was saying is the below facts in direct response to the original question. I wasnt mixing it with philosophy.
You cant without an analysis of the lift geometry. Ideally, it is a parallelogram linkage. If it truly were it would lift the same at the balls and any distance behind them. The closeness with which the 3ph setup matches this determines how much loss in lift you get as you go back from the eyes. The match will vary with the placement of pivot points on the tractor and implement and many are selectable on both ends. Trust #s the manufacturer provides is a conservative average. The best you can achieve is 1:1 -- this would be if the implement rose straight w/o pivoting at all wrt the tractor. The worst would be if the implement pivoted the same as the lift arms [or more:eek:] as it rose. Real life will show a variable % loss across tractor brands due to the non ideal geometry achievable....and to a small extent Friction.
larry
/ Conversion Factor for 3PH load capacity #88
Sure! How far out on the forks do you put the weight so that you have to use down force to keep the arms from rising. :p
Trimble Guidance System (A60462)
Trimble Guidance...
2022 Takeuchi TL12R2 (A60462)
2022 Takeuchi...
2019 Bobcat MT85 (A60462)
2019 Bobcat MT85...
2004 Freightliner FL70 Garbage Truck, VIN # 1FVABTCS64HM47795 (A61165)
2004 Freightliner...
2013 Ford F-750 Pak-Mor 16 Yard Rear Loader Garbage Truck (A61568)
2013 Ford F-750...
Giyi GY-CYHC Mini Quick Attach Side Shift Forks (A60463)
Giyi GY-CYHC Mini...
