txhawg
I was boxblading my drive with my 4310 and 2060BB last weekend for the first time. When using the BB on the 3pth, I found it hard (read impossible) to return the BB to the exact same position after lifting it to turn around or reposition.
I dropped the blade to the desired position, then I set the draft control locking thingy. The problem is that after I lift, then drop to the stop, the blade would never lower all the way to the same position. The lever would actually back off a little from the stop. I found this to be really annoying. I thought I would be able to just drop it and let it rip (no pun intended). Is this common for position draft control? If so, is there some trick in getting this to work correctly? Is there something wrong with my rockshaft? Am I being too picky?
