- Joined
- Aug 31, 2001
- Messages
- 65,912
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
You know how your top link is a solid bar with threaded ends? And you can adjust its length with a wrench by turning the eyes in or out? Well, you take that top link out and replace it with a hydraulic cylinder and connect it to a valve on your tractor (if equipped with spare valves, you may have to add a valve). Then by extending or retracting that cylinder, you change the angle of the implement in relation to the ground. With a box blade, it would make the blade cut more or less aggressively.
It can get kind of expensive, and, well, you still end up with a box blade that's not ideal for driveway maintenance like you describe. I found that my box blade on my old IH2500b was very hard to get a nice level finish on anything. As you know, when the front of the tractor goes over a bump, the box blade digs down, and when the tractor goes into a swale, the box blade lifts up some and dumps part of its load. I kept ended up with wavy areas and it took many, many passes over an area to finally get to level. I no longer need a box blade. If I ever get to the point that I need to do driveway maintenance again, I'll get a land plane, as I linked to in a previous post. I think it's a better tool for the job.
