Controller Setup
/ Controller Setup #1
B7510HSD
Kamiah,ID
Kubota B2601
I have a new P2 controller and the manual says hold the manual brake lever over and set to 6 to start with... Do you do the initial setup and testing
With an empty trailer or does it matter?
/ Controller Setup #2
for an empty trailer i set to zero then did some on pavement testing increasing the gain untill i got to a point were i got some trailer brakeing without locking up the wheels.
/ Controller Setup
Perfect will give it a go see what happens!
/ Controller Setup #4
The book way of doing it is adjust to a point where you can lock up the wheels at 10 mph then back them off to the point where they just will not lock up.
You must adjust each and evey time as load varies.
Chris
/ Controller Setup
Thanks Guys thats what I thought!!
/ Controller Setup
I just went out and tried it out worked great can't wait to load up the tractor and see what it does!! Thanks for all the help!
/ Controller Setup #8
There are a couple of other setting to play with as well. I had a prodigy a couple years ago and they are very good controllers.
/ Controller Setup
I need to read the manual a little more but that takes all the fun out of it! :)
2015 Ford F-550 4x4 Liftmoore 2550 5,000lb. Crane Service Truck (A64556)
2015 Ford F-550...
2015 Mack GU713 T/A Wet Kit Day Cab Truck Tractor (A64556)
2015 Mack GU713...
2010 Dodge Grand Caravan Van (A64557)
2010 Dodge Grand...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2002 FORD UTILIMASTER 4X2 S/A STEP VAN (A67148)
2002 FORD...
JLG TELESCOPIC FORKLIFT (A64279)
JLG TELESCOPIC...
