Backhoe Control Valve Assembly leak on backhoe
   / Control Valve Assembly leak on backhoe #11
Good your back in business. The white nylon washer looking one is a wiper ring and a backup for the black rubber o-ring that really does all the sealing work.
Thanks Victor, I figured as much which is why I did the black o-ring also. the white o-ring did look like it rolled over on it's self. Glad that is done, next will be o-rings where driveshaft goes into front pumpkin, purchased them just need to find time. Thank you very much for your help.
   / Control Valve Assembly leak on backhoe #13
I know this is an older thread, but it applies to what I'm doing. Have a KB 2365. Top of body looks the same as Joel's. It's a Nimco body.
My question is I have the two (2) outside stems pulled from valve body, would like to know if any of you pulled the two (2) in the middle ones while body was removed from hoe?
Thanks!!
   / Control Valve Assembly leak on backhoe #14
Just an update for anyone who needs the valve seats and o-rings. Not even Kioti have these anymore. I contacted Nimco, the maker of valve body. Which mine was a CV 126. They had a rebuild kit for $103.68 plus shipping.
Better than going to a hydraulic shop and trying to match.
   / Control Valve Assembly leak on backhoe #15
On my KB2375, I had the entire valve block disassembled. I had to replace the actual casting of the valve block and it's spool for one of the stab legs but this was about 12 years ago. Taking it all apart and reassembling wasn't that hard. Just laid out the parts and kept them clean. When you say "stems", do you mean the spools? Each of the six valve blocks, if I remember right, are almost identical except for a check valve. I would need to review a diagram that a dealer provided me years ago.
That's nice Nimco still has the parts and definitely much better than trying to match up as you mentioned. Via this post: https://www.tractorbynet.com/forums/kioti-owning-operating/405581-backhoe-control-valve.html, another member is looking for parts. Apparently Kioti isn't carrying them anymore according to this reputable dealer, Michigan Iron and Equipment. The dealer was trying to find specifications on the spool shaft seals for a member to hopefully find a match. If you have any contact information you'd like to share, I'm sure it would help some members including myself when parts are needed. I don't remember if mine is the CV 126 but will check my prior paperwork. I hope Nimco still has parts for mine if a different model. Thank you for any information you can provide.
20 LOWBOY BUMPER PULL TRAILER (A55745)
20 LOWBOY BUMPER...
Bell B30E (A50123)
Bell B30E (A50123)
2021 Club Car Carryall 500 Utility Cart (A55851)
2021 Club Car...
KUBOTA X1140 CREW RTV (A52706)
KUBOTA X1140 CREW...
SARLO MOWER (A55758)
