control mystery
/ control mystery #1
54rover
Morrisonville,ny
ford 1210
I recently purchased an aftermarket loader for my ford 1210. I installed the loader and after fiddling with hose connections got everything working correctly. Ran the loader for about a week pretty regularly and all worked fine. Two days ago I moved some stones to a pad I'm building. Lowered the loader to just above ground and floated it to sit it on ground. I got back in tractor after unloading stones. Lifted the bucked, went a little to far so I placed the joystick in down position and the loader raised up??? Double/triple checked and loader is raising up at both the raise and lower position. Put it to float and nothing happens. I tried the roll back function and this did not work either, dump function is fine. Shut tractor down and placed joystick in float position and bucket did lower although VERY VERY slowly, nothing like normal. This has me confused how this could be happening, very odd! It happened all of a sudden no issues at all before hand.
Any ideas???
/ control mystery #2
Depending on the hose plumbing and system type, your 3 point hudraulics could be affecting the loader function. On my Kubota, if I have a heavy load on the 3PT or the lever and 3pt positions don't match exactly, the raise/lower functions act strangely. It will load up and refuse to lower. Is this a possibility?
/ control mystery
Rosner THANKS!!
I turned down the rate limiter to off to my 3pt. Opened this back up and everything is working as should be!! It seemed like a return restriction but didn't think the limiter was in series with loader hydraulics. THANKS again!!!
/ control mystery #4
Glad that solved the problem! Interesting to hear the flow control is plumbed in series with the loader return.
2023 Bobcat T770 (A60462)
2023 Bobcat T770...
1996 FRUEHAUF 45' SLIDING AXLE FLATBED TRAILER (A59911)
1996 FRUEHAUF 45'...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2021 UTILITY VS2DX 53FT DRY VAN TRAILER (A59905)
2021 UTILITY VS2DX...
NEW HOLLAND TS115A TRACTOR (A62130)
NEW HOLLAND TS115A...
