Continuous 12 volts
   / Continuous 12 volts #1
BeeFarmer
S.E. Ohio
TC 33D
I have a TC 33DX and without running a wire directly to the battery or engine area is there a 12 volt source near the rear that is on all the time?
thanks
   / Continuous 12 volts #2
I didn't see a response yet for your model, but my TC40D has a single connector in the bundle running to the right rear turn indicator that fits your requirements. You might look there.
Thanks! Are you talking the right rear flasher? Thanks again.
Checked it out, doesn't appear to be the same with the 33. I have the flashers, tail light, and spot light only. Any one else have an idea? Thanks
   / Continuous 12 volts #5
It would only take 5 min to run a single hot wire from the battery. Put in a fused link and ground it at the location you will use it at. What are you going to hook-up to it? Why do you want to use an existing one?
Hooking up the switch side of a radio. Otherwise it looses it's memory
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
UNUSED Clear Multi-wall Polycarbonate Pane (A53117)
UNUSED Clear...
1985 Eager Beaver 9D0W Tri-axle Flatbed Equipment Trailer (A50322)
1985 Eager Beaver...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2015 Chevrolet Silverado 2500 HD Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
