Continuous 12 volts
   / Continuous 12 volts #1
BeeFarmer
S.E. Ohio
TC 33D
I have a TC 33DX and without running a wire directly to the battery or engine area is there a 12 volt source near the rear that is on all the time?
thanks
   / Continuous 12 volts #2
I didn't see a response yet for your model, but my TC40D has a single connector in the bundle running to the right rear turn indicator that fits your requirements. You might look there.
Thanks! Are you talking the right rear flasher? Thanks again.
Checked it out, doesn't appear to be the same with the 33. I have the flashers, tail light, and spot light only. Any one else have an idea? Thanks
   / Continuous 12 volts #5
It would only take 5 min to run a single hot wire from the battery. Put in a fused link and ground it at the location you will use it at. What are you going to hook-up to it? Why do you want to use an existing one?
Hooking up the switch side of a radio. Otherwise it looses it's memory
Landhonor RSB-14-80W, 80" Rock Bucket (A52384)
Landhonor...
2014 International PayStar 5900i S/A Flatbed Truck (A52377)
2014 International...
Athey 7-12 Force Feed Loader (A52384)
Athey 7-12 Force...
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2021 CATERPILLAR...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
1995 HESSE CORPORATION BEVERAGE TRAILER (A53843)
1995 HESSE...
