considering this trailer...
/ considering this trailer... #21
We're an hour from the nearest state forestry pumper truck, which serves as our fire protection. I've got everything around the house well cleaned out within 100 yards. As fire season comes on I whack the weeds and grass back with a brush hog. Flammables (gasoline) go out into the middle of the field, not near the house. Disc the perimeter if a fire approaches. House itself is reasonably fireproof, with no wooden decks and stucco exterior walls and a metal roof. Fire would have to get up into the eaves before it took off. More likely is an accident with the wood stove when we have 3 ft of snow on the ground.
We're very remote, land is as much vertical as it is horizontal, lots of rocks and ponderosa pine and brush. Somebody on foot with a shovel, wet gunny sack, and 5 gallon bladder bag would in many cases be more effective than some humongous double axle trailer with 500+ gallons of water being pulled by a shiny new $50k pickup. If it's a brush fire and not much wind, the gunny sack may be enough. If the trees are crowning out, you will need a D8 and multiple aircraft doing retardant drops. You can always imagine wanting more water, an appropriate size depends on the terrain and ground cover and towing vehicle and budget.
For my firewagon, I'm thinking a single 275 gallon IBC tank. Also on the firewagon: a Honda WX10 pump, a couple hundred feet of 3/4" garden hose and nozzle, an appropriate suction hose, gunny sacks, bucket, shovel, polaski, saw, 2 meter amateur radio, cb radio. Weight of the water is 275*8.34 = 2294 lbs, all the rest (except the trailer itself) would add less than 10% to that.
The trailer could be my small 4x8 with a single 3000 lb axle, more likely the bed of my 25 yr old 4wd F250-HD pickup. Have a reservoir uphill (perhaps multiple IBC tanks) to quickly fill the tank on the firewagon. Or just use the Honda pump from a pond, would take 10 minutes at the WX10's rate of 30 gallons/minute. When fire threatens, tank on the wagon might remain full for weeks.
That trailer you are looking at could be fine, depends on how the wheels are attached, $200 seems a very good price. Before spending days making it right, load up 1.5x the weight you plan on having. (I've seen 6000 lbs on a 3000 lb axle). Check how badly the wheels bow out or flatten. Then hook it up and drive around in the worst of your local terrain as if you have a hot brush fire chasing you. If it survives, go for it.
Another option somewhere between a single axle and the M200 trailer would be a small beat up double axle horse trailer. These can be quite cheap, just cut the top off. Make sure it has working trailer brakes if your towing vehicle can't safely stop all that weight on a slope.
/ considering this trailer... #22
A town near here had a 4wd Dodge Powerwagon from the mid 1960's, fully equipped as a fire truck with 300 gallon tank and pump, was being sold for $3k. Very cool! I probably should have bought it for use on the property. What stopped me was insurance for taking it out on public roads, which severely limited the use I might have for it. Since it's rated at over 1.5 tons, I was told by multiple insurance agents that I would need to buy yearly commercial insurance for it, no chance these days to just have part time "farm use" insurance. Would cost well over $1k/yr. Ironic that the insurance companies kept me from getting a fire truck to protect the property.
Sliding a 275 gallon frame tank and a WX10 pump into the bed of the $4k F250-HD that I needed anyway pencils out way better, but not nearly as much fun.
/ considering this trailer... #23
Peace wrote "Hagerty".
Interesting, might work, would have considered them. Not clear they would insure a 2 ton truck. They do have a $3500 minimum valuation (which I think was exactly the asking price of that firetruck). I would have been looking for just enough cheap liability insurance to be legal. The minimum valuation suggests Hagerty might be a bit more upscale, perhaps preferring to insure the paint job on your Jaguar. Anyways, I need the F250-HD for occasional use with the gooseneck stock trailer and equipment trailer, so using that same truck for fire is the more practical solution. Additional cost is mostly in the WX10 pump. But having an old firetruck would be very cool.
Edit: I'm leaning toward the F250 rather than the 4x8 trailer. Easier to maneuver.
Everyone loves their honda power equipment, but I haven't seen a proper fire pump that's honda branded yet.
Honda powered, maybe.
The Honda WX10 has a great price point, but its maximum pressure is 52 psi - this isn't a fire pump - that's typical household well pressure. I'd rather have significantly higher psi to get better spray and distance.
My thought is that the pump is probably the place to put the money in such a setup - you can have the best trailer, biggest tank, etc, but with a normal pump it's not going to push the water very far.
This pump is pricey, but it's got great stats.
/ considering this trailer... #25
What kind of axle is it? Looks like a small size square rod. ?????
Looks like a 2" 2000 pound - unless it is simply a sq tube - either way, not good. Water is a heavy load. Probably will bend the first bump it hits. The heavy large pipes gives the impression it will load heavy, but that axle does not. Might want to look at the rating of those old tires. What did they load when new?
/ considering this trailer... #26
Ning wrote: "The Honda WX10 has a great price point, but its maximum pressure is 52 psi - this isn't a fire pump - that's typical household well pressure."
Depends on your needs. If you are fighting an apartment fire and have hydrants nearby, go big. If it's a spot fire on a canyon wall, it's shovel, bladder bag, and wet gunny sack. The WX10 would be fine for helping stop the head of a brush fire. If you have a rig with a 1000 gallon tank and a pump that does 200 gallons per minute, it's may be too big to get near the fire in rough country. And after dumping all that water in 5 minutes, the round trip to the nearest water source for a refill might take an hour.
The point of PSI isn't necessary GPM - while a pump capable of higher PSI often can also do higher GPM, it's not always the case.
I'd like high PSI choked down to the same GPM and just push the water out farther; 20 GPM at 50psi lasts just as long as 20 GPM at 125psi, and the pumps aren't much different in size and weight.
/ considering this trailer... #28
400 gallons of water is about 3,300 pounds. Be extremely careful of the balance point of the tank so it is tung heavy. I would pop for a two axel trailer minimum.
B. John
/ considering this trailer... #29
Retired fire fighter and antique apparatus collector. The previous posts are spot on; fire trucks that are going out of service are basically dirt cheap. Just make sure the pump has passed an annual pump test and that the tank is not leaking. Like all heavy trucks repairs are expensive, but given the minimal use you would give it I wouldn't expect that repairs would be likely. And if it does need a major repair scrap it and go get another one.
The one downside is it needs to be kept somewhere that will prevent it from freezing, But that is also true for your home made rig.
Look on SPAAMFAA's web site as well as the government auction sites.
I live in a rural area and my "extinguisher" is a hose reel in my garage with enough hose to reach everywhere in the house. If you have a good detection system, i.e. smoke detectors and heat detectors in the attic to alert you of an incipient fire, a green line will put out a lot of fire.
Planning a response is great, but practicing good prevention is even better.
B. John
maybe this one
If my land was flat, maybe ;)
DEUTZ MARATHON...
2005 Wacker Neuson PDT3A Portable Diaphragm Pump (A59228)
2005 Wacker Neuson...
2025 32in. Hydraulic Tilting Mini Excavator Attachment (A59228)
2025 32in...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
Hydraulic rail grinder (A61307)
Hydraulic rail...
2014 Chevrolet Silverado (A60352)
2014 Chevrolet...
