Considering the L3130 for dual role - please advise!!!
   / Considering the L3130 for dual role - please advise!!! #11
LSUalum said:
Do any of you with L3130s feel it may be too heavy for a lawn ( for mowing)?
Dual purpose out of the 3130 is why I purchased it.Landscaping an exisiting yard and cleaning up tree tops left by the timber co.I drive on the lawn daily.
Using 4wd on lawns will make a quick mess on dry ground.I dont use a finish mower with it but do cut the pasture often.It is small enough to manuver between trees and stumps in the woods.It works well for grading the 1/4 mile driveway too.
   / Considering the L3130 for dual role - please advise!!! #12
I have a 3130 but I got wider ags put on it few extra $$$'s. They are the size on a 3830 so I still have the benefit of the traction plus a little bigger footprint for weight distribution. Diameter is the same but the width is different.
There are no perfect tires out there for ALL the conditions but I tried to make the best effort to have the most versatile for my needs.
   / Considering the L3130 for dual role - please advise!!! #13
Veranidae said:
I perceive the L3130 HST 4wd will effectively augment the KX161-3 on residential lots. Will it be sufficient for use on our often unforgiving terrain in New Hampshire, when necessary? At the same time, is it too heavy for regular grounds maintenance? Would the New Holland TC35DA, equipped with SuperSteer, make more sense? It's crunch time, and I'd love some feedback. I would prefer the Kubota, but fit,form, and function are critical. Thank you.
I am in NH as well and went for a new L3400
   / Considering the L3130 for dual role - please advise!!! #14
Theowegian said:
The L3130 is about 1000 lbs more compared to the B3030. Why not consider the B3030? Same HP but lighter. I have the L3130 and like the weight since I dont care about the yard. I really dont think the L3130 is too heavy, tho. I think either the L3130 or the TC35 is near perfect for grounds work.
Second that motion, Mr. Chairman.;)
Or the B7800 if $$ is a factor.
(2) 48" HANG ON FORKS (A54756)
(2) 48" HANG ON...
Parker Gravity Wagon (A50775)
Parker Gravity...
2019 CATERPILLAR 303.5E2 CR EXCAVATOR (A52705)
2019 CATERPILLAR...
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A55787)
2007 Godwin Pumps...
IRGC40 Electric Tricycle (A55758)
IRGC40 Electric...
2006 STERLING L7500 DUMP TRUCK (A51406)
2006 STERLING...
