Considering LS tractors or not?
   / Considering LS tractors or not?
Thx Hutchman, it seems that if you go with a used tractor you don't really know what you are getting. We have an LS dealership not too far from us. So I AM seriously considering the LS 4046 or 4047. Just want to know from everyone if they've had a bad experience with an LS tractor from a mechanical standpoint.
   / Considering LS tractors or not? #12
The XR4046 is the newer model and has a tier 4 Shibaura engine. The R4047 is the previous model with a tier 4 interim Mitsubishi engine. Tier 4 interim has fewer emission controls if that makes any difference in your choice. Both engines are good.
   / Considering LS tractors or not? #13
I think the reason you don't see a lot of reviews is because of the low rate of repairs required. Many folks only do reviews when they have something bad to report.
Take a look at the post here on TBN for LS Tractors and you will see very few problems with most being operator error or improper operation. There have been some design changed required over the years and LS has stepped up and made changes, retrofitted tractors affected at no charge. This and the great 3 year bumper to bumper + 5 year powertrain warranty make for a very good buy. I think only Kioti matches the warranty duration.
   / Considering LS tractors or not? #14
True. Mine was 2-1/2 yrs. old when I bought it. I went through it with a fine tooth comb and changed every fluid and filter on it.
The only thing (besides frame) I found wrong with it were cosmetic things. The seat was tore up and I replaced that with a aftermarket seat from Northern Tool. Some parts on the 3pt. hitch were modified for some reason and it took about $100 in parts to put it back to original spec. Overall I feel like I got a very good deal on it and I think it is going to suit my needs just fine.
Our property was just logged and I've used it to fetch large tree trunks the loggers left for me because they wouldn't fit through their whole tree chipper.
I recently got some pallet forks for it and the first large thing I lifted was a new backhoe attachment attached to its steel shipping crate. I estimate everything was around 1800-1900 lbs and I lifted it from the thin side to get it off the trailer since I couldn't fork it from the side due to the trailer having rails .... so all the weight was way out front. Was worried but it did it no problem at all. My rear tires are loaded and I had a 500lb box blade for ballast. Set it down and forked it 'the right way' and put it up without any trouble. I was impressed!
How many hours do you have on it hutchman ?
   / Considering LS tractors or not? #16
Had 480 on it when I received it. Now has 527.
Previous owner was a Vet. in SC that had a hobby farm. Dealer said he traded up to the R4047 with HST. He basically wanted HST. Mine is gear ... 12 forward/reverse fully synchronized with shuttle.
   / Considering LS tractors or not? #17
I bought an LS P7010C in October (2014). I have about 60 hours on it and have had ZERO issues and ZERO regrets.
Who else sells a 72 HP, 4WD, cab, 3 remotes, 5 year warranty, 3500 lb loader capacity tractor for 37k?
CT
   / Considering LS tractors or not? #18
.... here is my seat hacking thread with pics:
http://www.tractorbynet.com/forums/ls-tractors/312499-ls-seat-hacking-post3777196.html#post3777196
Must of been a sacrilegious mod putting a Deere type seat on my LS as nobody said a word about it :) It's more comfortable than the original and doesn't squirt water up my butt.
My thinking is I'd rather pay $90 for a seat I can get local if I mess it up vs. the $300 dealer wanted for the original seat replacement ... that would probably crack again.
   / Considering LS tractors or not? #19
I have 130 hrs on my R4041H that I bought in Oct 2013. Had 1 minor issue, the dealer picked it up, fixed it, and returned it same day. Very happy with mine, it has done everything I have asked of it.
   / Considering LS tractors or not? #20
I am very happy with my XR4046 to date. Biggest complaint is the cab light auxiliary switches aren't back lit. For the price a cab is very nice to have and makes off better resale.
UNUSED RAYTREE RTSG30 TRANSVERSE STUMP GRINDER (A54757)
UNUSED RAYTREE...
2015 DIAMOND CITY 78" X 18' DBL AXLE TRAILER (A54756)
2015 DIAMOND CITY...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2006 Toyota Tundra 4X4 Pickup Truck (A55788)
2006 Toyota Tundra...
UNUSED EINGP MSC2030F 20' X 20' ALL-STEEL CARPORT (A54757)
UNUSED EINGP...
2023 INTERNATIONAL MV607 21FT ROLLBACK (A54607)
2023 INTERNATIONAL...
