Considering a high hours 4720... Thoughts?
/ Considering a high hours 4720... Thoughts? #1
SnowX
John Deere 2320
I'm considering a 2012 4720 with 3500 hrs. I know it's hard to tell the condition without knowing how the previous owner maintained the machine, but anything I should know about an older 4 series with this amount of hours? How do the turbos hold up?
I've had a 2320 for the last 5 years and only put on 200 hours since purchasing it used (currently at 2800hrs) so my use is fairly light.
/ Considering a high hours 4720... Thoughts? #2
I have a 4520 cab tractor with 3800 hours - runs awsome -no leaks or issues have seen these with 7000 plus hours
/ Considering a high hours 4720... Thoughts? #3
My only complaint is the antifreeze/oil leak coming from the timing cover housing at just around 1000 hours. I'll live with it until something needs replacing on the front of the engine.
/ Considering a high hours 4720... Thoughts? #4
Pre 4 or post 4? Hours mean little. Emissions component failure means more. That and maintenance. Think I'd have a competent tech look it over first.
I believe all 4720s are pre-emissions, I think that's why they changed the model numbers when they went to tier 4 compliance to 40XX to differentiate between the two.
Regardless, this one is pre-emissions. I'm buying it from a Deere dealer, so I'm assuming they've been through it.
/ Considering a high hours 4720... Thoughts? #6
Don't count on it from a Deere dealer. Anything other than green is strictly off limits to them. Bought my last M from a Deere dealer as well and candidly, he didn't have a clue what he had so I whittled him down on price. I knew exactly what he had. Gave him 18 for it and had them deliver it to my Kubota dealer who promptly offered me 30 for it. I still have it btw. Had my dealer go 100% through it. Cost me 5 grand in labor and parts. Worth every penny. Great tractor. They even put it on the dyno and it made 92 pto horsepower at 2200 rpm.
I went and looked at it on a Sunday when they were closed and I took my key with me (all M9's use the same key). Started it and drove it around the lot and went over it very carefully. I knew exactly what I needed and what it was worth to me and I got it for under what I was willing to pay. Not like I don't know my M9's in as much as I've had one (bought new in 2004). Only thing this one don't have is the 12 x 12 or the 2 speed PTO, which my other one has. This one is an 8 x 8, single speed pto, not that I use the 1000 rpm 21 spline pto much, other than running a grain leg.
Good luck with yours but I'd not have high hopes on any Deere dealer checking out an orange tractor at all.
/ Considering a high hours 4720... Thoughts? #7
I'm confused. The 4720 is a John Deere 4720, isn't it? There is a tendency for folks to OMIT the brand and just throw out a model number here. But in this case, I thought that 4720 was referring to a JD4720. The Deere dealer should be the expert on it.
Unused 2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2023 Land...
2021 JCB 300T SKID STEER (A65056)
2021 JCB 300T SKID...
🚜 2022 Mahindra 1635 HST Tractor Package – ONLY 36 HOURS – FULL SETUP READY TO WORK!
🚜 2022 Mahindra...
Generac SD135 136kVA Standby Diesel Generator (A66734)
Generac SD135...
2021 Ford Explorer SUV (A66738)
2021 Ford Explorer...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
