Consider cast weights instead of liquid in tires
   / Consider cast weights instead of liquid in tires #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
My choice is cast weights over liquid in the tires. It wasn't always that way but happened fast after I got a flat in a filled tire two miles back in the woods in rural Maine. I was on my own and it was a big event. Some people need filled tires because of severe slopes but for most of us, take a look at cast weights if you need it.
If too much, I can take some off. If too little I can add some and when I'm done forever I can sell them for what I paid. Plus, I think they feel better over filled tires. They don't ride as hard either. What's not to love? Here are a couple pics to tell my tale and remember I'm biased because I live on flat ground.
These first pics are off my JD5520. I have two rear weights on each side and they are a great counter to the loader when I pick things up. On the front I have the starter weight block. I think it's 285 lbs. I think the back ones total 500 lbs. For the front I used to add up to 800 lbs of suitcase weights for tillage things or heavy lugging but since I got away from that they haven't been on since. Those are radial tires and that adds a few hundred extra lbs.
These next two are of my Kubota L4300. It's FWA but is light in the front end and I often pick up 1000 lbs. Without the weights, it's bouncy. Sometimes I bolt some or all on securely and sometimes I just run a threaded rod through and put nuts on. If I'm around the house I will do that and in decades have never lost a weight that was just hanging there. Oh, this is a homemade front weight bracket and NH skid steer weight knock offs. I had the weights so made it work.
These last two are on an MX5100. Sometimes I take two off so I can hook tie-down straps for trailering. If I'm not on concrete, the weight stays on and it makes the tractor handle much better when it has a heavy implement on the back.
That's my story and I'm stickin' to it. Consider cast rather than fluid but that's just my personal opinion.
   / Consider cast weights instead of liquid in tires #2
My understanding is that cast wheel weights do offer the same counter balance as filled tires.I too have had flats with filled tires;a PITA for sure but a necessity.
My flat was on an 18.4 x 34 tire and on the other side of the property and waaay back in the woods. There were no tire service trucks where I lived and no one but me and the incessant black flies and mosquitos. Plus it was Spring and the ground was soft and muddy. I started with a 2 mile walk home.
   / Consider cast weights instead of liquid in tires #4
I like wheel weights too. I had 5 on each side to cover the stub axle on my 3020.
   / Consider cast weights instead of liquid in tires #6
I have filled tires and cast weights. but agree if you can get by with one or the other cast weights will work well. Cost keeps a lot of people from using them more and we have only fluid on some of ours.
   / Consider cast weights instead of liquid in tires #7
We went with weights on the IH 656 back in '1990 when the new set of tires went on. We also went with 5 sets on each side. Luckily, we found a eq. jockey that had stacks of the split weights that a lot of guys don't like, and got them cheap. Since we had to put them on by hand, we love them..!! Plus the fact of no calcium to kill grass/trees, if you have a tire leaking.
   / Consider cast weights instead of liquid in tires #8
The logic of using them is hard to ignore. Plus, they put the weight on the outside, giving even more stability that loaded tires would. I think they can be pricey, but I also think they would hold their value, if they can be used on more than one particular model tractor?
   / Consider cast weights instead of liquid in tires #9
I got both..Filled with added weights.
   / Consider cast weights instead of liquid in tires #10
Cast weighs have their place, and for me that is the front of the tractor. Cast on the back adds width and there is always some moron thinks a tractor can fit through a gap smaller than the tractor. Then they blame you for being to wide. For me, is less hassle to have liquid rear. Also I am seldom far from the road. Horses for courses.
2007 Ford Five Hundred SEL Sedan (A54815)
2007 Ford Five...
2013 Chevrolet Equinox LTZ AWD SUV (A56859)
2013 Chevrolet...
2002 TOYOTA 7FDKU40 FORKLIFT (A57880)
2002 TOYOTA...
2005 Kaufman Trailers Car Hauler Trailer (A55787)
2005 Kaufman...
2011 Ford F-150 Ext. Cab Pickup Truck (A55973)
2011 Ford F-150...
2012 BMW 328i Sedan (A55758)
2012 BMW 328i...
