consider a wrecked trailer?
/ consider a wrecked trailer? #2
Not for that price
/ consider a wrecked trailer? #3
Expensive parts, and possible hidden defects.
Bruce
/ consider a wrecked trailer? #4
Not for that price
This.
Save yourself the trouble and just go buy one that is not wrecked. I've tried to save money on stuff like this before and I always end up wasting a bunch of time and $ trying to make it work.
/ consider a wrecked trailer? #5
I would consider it but not for the current asking price. Might not be that hard to fix and would make a good second non tilting trailer.
/ consider a wrecked trailer? #6
This.
I would only give scrap price, maybe $700 tops.
Heck, a new one is less than the cost to fix that POS money pit!
Chris
I should have mentioned I wasn't thinking of offering asking price.
I suppose the question is, what WOULD you offer for it. Let us assume the axles/brakes/tires are in fact good.
/ consider a wrecked trailer? #8
Have to see it but probably no more than $500
maybe Diamondpilot's $700 but probably not.
/ consider a wrecked trailer? #9
With a bent frame, and other damage, you would need to get a trailer to get it home, then a lot of money for repair. I don't know if it would ever be right, and it might chew up tires if the frame is screwed up. I think it is scrap only, it would take lots of money and time, and may never be fixed right.
/ consider a wrecked trailer? #10
I wouldn't touch it if it was free. You will never get it right even if you bury it in $100 bills.
My 2 cents worth.
Sent from my iPad using TractorByNet
/ consider a wrecked trailer? #11
No reason for it to chew up tires, if you get it right.
If you don't have the equipment, or the ability, avoid it.
I have fixed truck frames a lot worse than that.
/ consider a wrecked trailer? #12
I wouldn't make an offer. The way the ad is wrote you can tell they're not seeking offers, but want what they ask. They think it's an awesome deal someone should jump on, so awesome that if folk are too stupid to see what an amazing deal it is, they'll fix it themselves and sell it for a whole bunch more money, or so they say...
You can see in the pics it is twisted at least 9" or more (check the alignment and count the deck boards on pic 6 of the ad)... The $500-700 mentioned above is all that it is worth in the condition it sets, tops. At best you end up with a pair of axles, suspension, the tongue, and some bits of hardware. The rest needs redone from scratch. If you could somehow pull that 9" worth of bend out of it, you're going to have to add hundreds of pounds of extra bracing to keep it square and support the areas that were bent or stressed by the bends. I'd personally chop it into pieces to use the straight parts as bracing for an entirely new trailer frame and recycle the rest.
By the way the ad is wrote I have a feeling they would take $500-700 as an insult and be a real pr1ck. I'd call and go look, but I'd refrain from making an offer, just watch for a month or so while he wakes up to the fact that is an insane amount of cash for twisted steel. When/if you go look, take a jack with you and raise it up and spin each of the tires to ensure they still rotate properly. Good chance with the impact that unit took, the axles are likely not that great anymore...
/ consider a wrecked trailer? #13
Rule of thumb for me on salvage is to determine what is still usable & of value to me. Determine what retail for those items is then pay less than half of that amount. Other wise I would not save enough to cover my labor spent recovering those items.
The axles are 8 bolt but what weight capacity? What is the ply rating of the tires? Is there a spare tire? is the lighting system still usable? Does the jack still work? How much will the scrap portion of the trailer weigh to help off set the purchase price? Where I am scrap is around $185 a ton.
$700 as a max price sounds about right.
/ consider a wrecked trailer? #14
Rule of thumb for me on salvage is to determine what is still usable & of value to me. Determine what retail for those items is then pay less than half of that amount. Other wise I would not save enough to cover my labor spent recovering those items. The axles are 8 bolt but what weight capacity? What is the ply rating of the tires? Is there a spare tire? is the lighting system still usable? Does the jack still work? How much will the scrap portion of the trailer weigh to help off set the purchase price? Where I am scrap is around $185 a ton. $700 as a max price sounds about right.
Bingo!
/ consider a wrecked trailer? #16
I've repaired much worse! Repaired semi Tractors and Trailers, Trucks and Truck Bodies for over 30 years.
It looks like just the two side channels are bent and should be able to be straightened. Hard to tell just from pics.
The price IS too high and if they could fix it and sell it for way more they would.
If I really needed it would might go $1000.00 after checking for additional damage.
/ consider a wrecked trailer? #17
I've repaired much worse! Repaired semi Tractors and Trailers, Trucks and Truck Bodies for over 30 years. It looks like just the two side channels are bent and should be able to be straightened. Hard to tell just from pics. The price IS too high and if they could fix it and sell it for way more they would. If I really needed it would might go $1000.00 after checking for additional damage.
StimW;
I think that that the big difference here is that, with your experience, repairing Semi tractors and trailers is that a business or, more likely, an insurance company was footing the bill. If an individual is paying the bills the economics are way different. I personally would not touch this thing.
Still ..... My 2 cents worth.
My thought was you cut the bent frame rails at the end of the V tongue and throw them away. (or save them for some other farm project)
New 6" channel is welded on and axles attached. Check the sq of the tilt portion of the bed. If its still sq, drop it on the new frame rails and weld it on fixed. Cut off the bent steel ramps on the end and do something with the bent section at the end were the other tail light is supposed to be.
Judging from the rust on the bent areas my guess is its been sitting for a while likely from last year.
From other listings that 12u is listed at 15780 GVWR. that probably assumes a fairly hefty tongue weight but thats what its stickered at.
a similar PJ trailer is $6K new.
I think there $2500 price is based on a hefty $2K rebuild price with a street value of $4500 which I think is going price for a used version per googlefu.
Still not interested in putting the money in it.
/ consider a wrecked trailer? #19
Not even with YOUR wallet! ;)
/ consider a wrecked trailer? #20
2013 TRAILKING TKT12U TILT EQUIP TRAILER
would you buy it for parts? axles?
Can a trailer have a salvage title?
Rebuild from the tongue V back with new steel in a non-tilting version?
Their ad reads like a sucker-punch. IF they COULD economically rebuild it and sell if for more, they would have done so already. In my opinion, it's probably buying into a lot of headaches, that they already have discovered.
It's a "Pass" in my book.
2006 John Deere 250D 25 Ton Articulated Dump Truck (A61567)
2006 John Deere...
2016 DRAGON SAND CONVEYOR (A58216)
2016 DRAGON SAND...
2018 CATERPILLAR 315FL CR EXCAVATOR (A62129)
2018 CATERPILLAR...
2003 Dodge Ram 1500 Pickup Truck (A60352)
2003 Dodge Ram...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
2006 KENWORTH W900 (A60736)
2006 KENWORTH W900...
