djradz
Veteran Member
I am continuing to have a great deal of trouble connecting my Woods RM-306 mower drive shaft to the PTO of my new TC 40D. The splines are always just a few degrees off. Neither part has much movement. The tractor PTO is virtually impossible to turn by hand and turning the mower drive shaft is not much easier. I rebuilt the mower back in the spring so it is pretty tight, but by turning the flywheel, I can get it to turn. Trouble is, often, when I let go of the flywheel, the shaft returns to it's misaligned position. (I need a nother set of hands I guess). Does anyone have any suggestions? Is everyone's NH PTO nearly impossible to turn by hand? I'm thinking of looking into adding an overrunning clutch just so I have something I can turn. Can you turn such a device, at least one way, by hand? When I had my 1720, all I had to do was turn the PTO just a little to get it aligned. Apparently the PTO drive setup was different in that. Help!
