Connecting and Disconnecting Loader Hydraulic Lines: Tractor on or off?
   / Connecting and Disconnecting Loader Hydraulic Lines: Tractor on or off? #1
fordmantpw
Central MO
John Deere 2720
Hello all! I just received my JD 2720 over the weekend. I've never had a loader before, and I have a question on connecting and disconnecting the hydraulic lines. Does the tractor need to be off? Watching some YouTube videos, I've seen some with the tractor running while connecting the lines, but not disconnecting. I don't mind shutting the tractor off if necessary, I just don't like extra on/off cycles of the engine if it isn't required.
Thanks for the help!
PS: I don't have my loader manual yet since they forgot that with the tractor, but it should be here in a couple days.
   / Connecting and Disconnecting Loader Hydraulic Lines: Tractor on or off? #2
Yes! Shut down the machine move your control stick in all four directions at least 4 times to relieve pressure then disconnect lines.
That's kinda what I expected. Thanks for the advice!
   / Connecting and Disconnecting Loader Hydraulic Lines: Tractor on or off? #4
Off to make it easier on yourself. Trying to hook-up with it on is messy at times if you have to relieve the pressure by allowing fluid to escape. Also a little dangerous with fluid flying.
Valvoline Transmission Oil / Power Steering Fluid (A53117)
Valvoline...
Klemmfix Qwick Curb (A51692)
Klemmfix Qwick...
UNUSED Single Stall Portable Restroom (A53117)
UNUSED Single...
2007 Chevrolet Tahoe 4x4 SUV (A51694)
2007 Chevrolet...
Tennant 800 Ride-On Street Sweeper (A53421)
Tennant 800...
Attic fan with vent (A53117)
Attic fan with...
