connecting 8A hydraulic with out factory kit
   / connecting 8A hydraulic with out factory kit #1
freetown
Swansea
JD870
Has anyone ever connected hydraulics from 8A backhoe to a 870
without a factory kit? Any help would be great thanks
I can't find a kit anywhere
   / connecting 8A hydraulic with out factory kit #2
Your tractor appears to be open center, and if the BH has an open center valve on it, it should be no problem to connect the BH.
You need to know the flow path of the hyd fluid.
Somewhere at the back, there is a high pressure hose going to the 3pt .
A manual would be good to have.
You need to insert the BH valve is series with the flow path.
You probably need a QD's for the high pressure hose at the back, and a QD from the BH PB port to complete the flow to the side of the tractor for the 3pt.
When not using the BH, you would just plug the two QD's together and have your normal hyd flow restored.
Something like this.
Thank you so much. My BH has two hoses coming from it one male and one female so I guess I need to find hose to 3pt and split it to go to the 3pt and the BH at same time than just find a return for the fluid. I do have manuals for both tractor and BH. Do you think I'm on the right track with this or upside down on understand this. ..... thanks again for your help
   / connecting 8A hydraulic with out factory kit #4
You can't tee and go to the BH and 3pt at the same time.
If your BH only has two hoses, the return/OUT hose should go the filler cap.
Look at your BH and see if there is a PB port.
Do you need the 3pt with the BH on?
No I do not need both at once so I could quick connect at the 3pt... thanks again
1840 (A51248)
1840 (A51248)
2018 FORD F-150 XL CREW CAB TRUCK (A51406)
2018 FORD F-150 XL...
4 Unused Montreal ST205/75R15 Trailer Tires (A53421)
4 Unused Montreal...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
LIKE NEW John Deere 10 Lug Sprayer Wheels and Tires (A55301)
LIKE NEW John...
2008 Genie S-65 65ft Telescoping Boom Lift (A53421)
2008 Genie S-65...
