conlrol valve on bolens ht-20
   / conlrol valve on bolens ht-20 #1
jimrobert
mpls.mn.
1976 bolens ht-20
hi this is my first posting .i was thinking of connecting a second hydro. control valve on my bolens ht-20 . i was thinking that hooking them in sieres . then i could run another cylinder. any ideas? thanks
   / conlrol valve on bolens ht-20 #2
Welcome to TBN. :)
   / conlrol valve on bolens ht-20 #5
If your tractor is open center hyd, then you can add valves in series. The first valve should have a relief and a PB port to feed the next valve. Tank ports should go to tank.
You could also replace your current valve with a two spool valve with PB, regen and float, and use the current valve as the second valve.
Utility Trailer (A52377)
Utility Trailer...
2015 Ram 3500 Enclosed Service Truck (A52377)
2015 Ram 3500...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A52377)
2021 Freightliner...
2016 R and R Products 331 LP Reel Mower (A51694)
2016 R and R...
SCAN FOR HAULING AND FINANCING INFORMATION (A52705)
SCAN FOR HAULING...
Harrell 3605 (A50123)
