Confused About SEC Cable Size
   / Confused About SEC Cable Size #31
AEP will put in an RFID meter free of charge if you request it (if you have a mean dog, they'll insist on it. Ask me how I know!)...they would no longer need to physically read it...if you are close enough to the highway they may be able to read from there...I think they have about a 3/8 mile line of sight range.
REad it? Whats that? We have automatic reading meters now both gas and electric. They send a signal to a receiver, no more meter readers.
   / Confused About SEC Cable Size #32
I think the 4-1/0 means the lug is suitable for wires as small as #4 or asl large as 1/0. Your 2/0 is too big.
You might be able to clip a few of the conductor strands is about same size as until the #2 will slide in. The arger wire will help you mi9nimize voltage drop, and you won't have to go buy more cable :)
   / Confused About SEC Cable Size #33
For 100 A, in non commercial building, use 2 AWG aluminum or 4 AWG Copper .The gounding can be a size smaller.
In commercial buildings in which there can be a continuous load close to the limit step up a size.
Aluminum has a lesser conductivity than copper and it is much more prone to overheating thus the need for a bigger size than copper. When using aluminum it might be a good idea to use an antioxidant paste on the end of the cable.
   / Confused About SEC Cable Size #34
other things make differences as well, in free air versus Nm (romex), in conduit (de-rated when over X number of conductors), direct burial, believe it or not, even attic temperatures should be considered when sizing a wire.
Can one still buy NM in the USA??? I thought NM was replaced by NM-B, some years back....
2006 International 9400i (A55302)
2006 International...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
18" PIN ON BUCKET (A52707)
18" PIN ON BUCKET...
2012 AMERITRAIL (A55745)
2012 AMERITRAIL...
HELI 5K FORKLIFT (A58214)
HELI 5K FORKLIFT...
Black Steel Diamond Plate (A55758)
Black Steel...
