Conflicting Weight Numbers
/ Conflicting Weight Numbers #1
dlroy101
Bronze Member
Frederick, MD
I'm getting some conflicting numbers on the weight of the tractors I'm looking at.
I came up with an estimated weight of 3,000 lbs for a B7800 and 2,500 lbs for a B2410/B7610. This is including a FEL, filled R-4 tires, and all fluids.
One dealer told me about 3,000 lbs for a B7800 and another dealer told me about 3,350 lbs for a B2410. Equipped the same a B2410 should not weigh more than a B7800.
What's correct? I need some help on this. Weight is a big factor in my decision. Are Kubota's numbers accurate? I figured they were a dry weight. Also, how much would a L352 or L402 loader weigh on their own?
Thanks,
Darrell
/ Conflicting Weight Numbers #2
LA402 loader with bucket weighs 800 lbs. LA352 should weigh about 100 lbs less.
B2410 weighs 1480 with ROP's.
B7800 weighs 1740 with ROP's.
Filled R-4 tires will add about 400 lbs. A little less on the B2410.
Your numbers are fairly close. /forums/images/graemlins/smile.gif
I just got an e-mail from one dealer with the breakdown that he has on the weight. This is his reply:
B2410 - 1345lbs
B7800 - 1890lbs
LA352 - 1000lbs
Tire Fill - 1000lbs
Filling the tires actually adds a lot of weight to the tractor.
I just about choked when I saw that tire fill number. What are they using lead? Apparently there is some difference of opinion. I hope I guess this right, but I think there is a Kubota dealer, Messick, that frequents this site. If you read this would you mind chiming in?
Thanks,
Darrell
/ Conflicting Weight Numbers #4
No dought there are different ways to fill tires. Foam filling them adds a LOT of weight. One TBN member (don't remember who!) has a M9000 with foam filled tires and I believe it added around 2100 lbs.
/ Conflicting Weight Numbers #5
like he said, it depends what they are filling them with. We usually use water and methonal which is about 8lbs per gallon. If they are using a dense foam you can probaly get 1000lbs - but at the expense of some ride.
Kubota recomends 400-600lbs of balast on those tractors, personaly I can not imagine why you would want more.
2025 Spirit Electric Scooter (A61574)
2025 Spirit...
2012 Can-Am Spyder Motorcycle (A61574)
2012 Can-Am Spyder...
UNUSED ATSPOWER 40 GALLON AIR COMPRESSOR (A64281)
UNUSED ATSPOWER 40...
Great Dane Van Trailer 1989 (A63689)
Great Dane Van...
(1) UNUSED 9.5-24 TIRE W/ 8 LUG RIM (A64280)
(1) UNUSED 9.5-24...
2024 Ford Explorer AWD SUV (A61574)
2024 Ford Explorer...
