2manyrocks
Super Member
- Joined
- Jul 28, 2007
- Messages
- 9,548
There are different ways of building a retaining wall depending on how much earth is behind it, expected water drainage issues and the slope. Depending on what you have, you might not need to add anything. We just don't know without more information. A picture of your site would probably help everyone in knowing what you're actually dealing with.
The fabric covering for drains is called geotextile fabric. By the time you pay box store prices for the thinner "landcaping" material, you probably could have bought the thicker geotextile material from a building supply store or local farmers coop.
The installation of drain pipe is another area where careful workmanship makes the difference between a working drain and a nonworking drain. The general idea is to use the geotextile fabric as a wrap to keep sediment out of your drains which are set in drainage gravel. The fabric encloses both the pipe and the rocks to keep sediment out and the drain running free. Sounds duh to say this, but the drains need to be pitched correctly when installed to drain water. Sometimes they aren't installed with the correct pitch.
