Concrete slab with 3pt mixer
   / Concrete slab with 3pt mixer #1
sevilla
New England
L3830
Hi everybody, I have a few questions for a project I will start this spring (hope at least): I intend to build a 12 x 16 feet concrete platform on my driveway. My plan is to build 4 inch of concrete on 4 inch of compressed 3/4inch-crushed stone. Since I'm going to do it alone or, better, with my kubota 3830, I intend to divide the platform in 4x4feet sections separated by 1.5 inch space (the thicknes of the 3x4 forms. I live in an area with frequent and severe freeze-thaw exposure. So my questions are: will this plan work? do I have to fill the gaps between the concrete sections with expansion joint compound or sand and gravel is ok? I'm inclined to think that ice buildup in the joints may move the concrete sections rather than cracking them. Also which is your experience with a 3 point mixer and would it work in my case? I'm considering the Northern or the Tractor Supply ones which seem identical. Thank you very much for any advice you could give me.
   / Concrete slab with 3pt mixer #2
hi sevilla:
I used a 3 pt mixer this past summer with not so good results. while it technically WORKED it was only really good for very small pours, maybe a 3 cu foot job ( 30 shovels of gravel 20 sand and 10 mix) was all it would hold & mix. I have a 4500 lb tractor 28 hp unit, that amount of mix was all that the tractor & mixer would want on it with out fear of breaking stuff. the mixer I had spin too fast as well. with my PTO and engine at idel it turned fast enough that instead of mixing when it was sticky it would stick to sides of drum until it was nearly all way at top then fall off and drop to bottom of drum. this was a LOT of hammering stress on the 3 pt. while I suffered no damage it was apparent that with any more mix sticking like that and it would be easy top shear off something. Also that amount of mix was about enough for a footer for a pole in a pole barn, it wasn't enough to do much so had to make many small patches which is harder on every one involved and then small batch differences made the mix batches not stick all that great together. I was making a pour around an under ground tank for reinforcing only but was not impressed at all.
freeze thaw will push the slabs apart in the application you are looking for as well as mix may not be all that good. while they are better than HAND mixing, I would say only by a little bit. they are slow in my opinion as well.
SO if you want one rent one first, then try & buy a used one if you like it and finally as last resort get new... I don't think that you will be as happy with the result as if you did it as one solid reinforced pour using a truck to bring it in.
mark M
   / Concrete slab with 3pt mixer #3
I poured a 8x12 pad last spring for a bathroom building. It was a lot of work. I bought the largest mixer I could get 1/3 yard I believe, but you can't get that much into it so it took forever. I also split the pour into fourths and used an expansion joint. The job took me over three days to pour. If I were to do it again I would just have a cement truck show up and pour it in a few hours.
I do like my mixer and have used it alot for smaller jobs, my tractor is a JD 990 and I have had no problems with the 3pt or the pto being too fast.
   / Concrete slab with 3pt mixer #4
I second the idea of having a cement truck come and pour. Mixing yourself with a drum mixer can be hard work. 12 X 16 isnt much but still you're talking about at least a couple of long days labour, followed by back ache and blisters.
Better to get a buddy or two to come and help spread and level the pour, have it done and dusted in a couple of hours and grab the deckchairs and beer to sit back and admire the cement as it dries...
I like the idea of 4ft X 4ft "tiles" you are going to make. Would you have grass grow in the 1.5 inch gap? I have a neighbour that has 2ft X 2ft squares with a 2" gap and he grows fescue grass in the gaps... Looks really well I have to say. Dont know how it would work out for you if you have really hot summers though...?
Good luck with what ever you decide to do!!
   / Concrete slab with 3pt mixer #5
I 'third' the cement truck idea. With everything considered, it's not that much more expensive and it is a heck of a lot easier on the body. I've used mixers of all types, and they will work great for small jobs, but once you get above two or three yards of concrete, you're way better off with a cement truck. Your back will thank you... The mixing isn't the hard part, it's getting the mix into the mixer that kills you.
If you do go with a truck, you might consider doing a 6" slab instead of a 4". A 4" is a little under 2.5 yards, and the 6" will be about 3.5 yards. If you're using re-bar (you should), you could potentially forget about the complex expansion joints and that extra $100 for an extra yard of concrete will be money well spent.
   / Concrete slab with 3pt mixer #6
I fourth the cement truck. You will still be doing it yourself, getting the area ready to be poured and setting your forms, but not having to mess with mixing batch after batch of cement. And as others have mentioned, it probably won't cost you much more, in fact subtract the cost of the mixer and you are money way ahead.
   / Concrete slab with 3pt mixer #7
If you don't like the idea of a cement truck delivery due to costs (2.5cu yards is probably below their minimum) and or high labor involved in an instant pour, another alternative is to rent the portable wheel-barrow/trailer that many concrete providers have. It will hold 1 cu/yard and around here, costs no more than the cost of the concrete. You tow it home behind your truck and a hydraulic ram tilts the trailer/wheelbarrow up to spill the concrete. Of course your Kubota can still come in handy.... pour the concrete into your bucket and bring it to the slab. Aside from screeding and finishing the concrete, you should be able to complete this in a few hours (certainly in 1 day) with a minimum amount of back breaking work. Plus, this allows you to work by yourself if you like, at your pace. Rather than 4x4 sections, this method also allows you to do a single pour with rebar reinforcement although with the weather you have there, I recommend at least a 6" pour. If it is not a continuous slab, the sections most certainly will shift over time and create a trip hazard.
   / Concrete slab with 3pt mixer #8
The secret to pouring concrete is to have a solid base underneith it. Is the dirt alreayd compacted? Will you be adding or removing any dirt? If so, you need to be sure to compact it. When you add gravel, it must be compacted. Most people don't do this right and just spread it out and drive over it with a car. This will work in time, but nobody will spend the hours and hours that it takes to get it right. Others use a plate compactor, which is more for patios and light duty compaction as in paver bricks. If you use a plate compactor, get the biggest one you can and spend a few hours with it. Four inches is about max for what it can compact.
Having four seperate pours increases your odds of movement in one or all of them. Concrete expands and contracts from tempature. It's always moving to some degree, which is why it always cracks. To make it as strong as possible, you need the rebar to connect all four pads if you do it this way. I would use PT 1x4 lumber in between the joints and drill holes through it for the rebar.
If you are set on buying a cement mixer, compare the price and size of an electric one from a place like Home Depot or other stores. They work really well and don't involve having to keep your tractor running. If you have electricy handy, it's allot easier way to do it. You can also sell it when you are done quickly as there are about impossible to find used.
I've done up to 2 yard pours mixing cement in a mixer. It's a long, back breaking day that you will wish you hadn't started. Buying the cement in sacks from the store is expensive and not as strong of cement as you get from a concrete truck. The aggrigate (rock) is just small pea stone in the sacks.
For small pours like what you are planning, I like to rent a cement buggy from US Rentals. You get one yard in the buggy already mixed and ready to pour. Here, the going rate is $145 a yard, which is expensive, but if you only need a few yards, it's cheaper then the minimum on a cement truck.
Cement is one of those things that is very dificult to get a good result fron without years of practice and experience. If you have a nice house and this is going to be done where others will see it, I'd hire it done. I'm a General Contractor and know my limits on what I can and cannot do with concrete. A nice, finished pour that people will see isnt' something that I'll tackle myself.
For what you will pay for the cement mixer, you can probably have the whole thing poured by a crew of experts who will get it done right the first time with results you will be proud of.
If you mess up on concrete, you are stuck with the results. There is no forgiving or fixing a bad pour.
Good luck,
Eddie
Thank you all for the replies: it looks like my idea was a little ambitious. I'll check with a contractor. Thanks again.
   / Concrete slab with 3pt mixer #10
Concrete slabs are hard work and, if you're a novice, you'll probably be less than satisfied with your DIY effort. My DIY limit was reached with a 4x8ftx4" thick slab for my masonry barbecue pit. That was one long day.
Spend the $$ and have a concrete contractor do the job right.
Or, if you really want to do it yourself, do the site prep and forms yourself and then hire a couple of concrete workers to moonlight and help you with the pour and the finishing. Getting a good surface finish is not easy unless you have the experience and the equipment (magnesium floats, etc).
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
2005 Mitsubishi Lancer ES Sedan (A51694)
2005 Mitsubishi...
2004 CATERPILLAR D6R XL CRAWLER DOZER (A51406)
2004 CATERPILLAR...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
backhoe attachment for mini skid steer (A53421)
backhoe attachment...
RIGID POWER DRIVE/HAND HELD THREADER (A53843)
RIGID POWER...
