Some advice to slow/decrease cracks is to seal up the building and keep the concrete wet as long as possible. It needs to set but once the surface cure is set and troweled smooth (or brush finish) use light spray to keep it damp. after 10 or so hours a light spray to flood surface and keep it wet for several days. This is what i did, I used plastic nailed over window openings and kept all the doors closed. the morning after it was poured I sprayed it down 2 times and that evening ran hose to add almost an inch of water over top w old sheets as seals at doors. I did this for a week keeping it wet, the concrete is so hard it wont take any stain.
I did NOT cut any expansion cracks inside as I have radiant tubing in the floor, I DID cut them outside however this was a mistake. The cracks outside let water get under the slab and it heaved & cracked one triangle section. Inside there is a 2foot crack hairline no separation right at the roll up door by the 6x6. it is not noticeable no cuts to catch dirt much happier w inside than outside where cleaning cracks is a pain, they are sealed to for this winter so will see how it's 4th winter is.
Mark
