Concrete slab thickness vs.footers
   / Concrete slab thickness vs.footers #1
USAFpj
SC
1957 841 Powermaster
About to do a 30x40 slab at 4in of thickness; not sure what the PSI rating of that will be. I imagine that when concrete is poured, it is thinner in some areas, and thicker in others. If I eventually want to put a 2 post lift in, the consensus is to go at least 5in in thickness on the slab. However, the company that is building the pole barn says that they just pour a footer in the specific area that you want your lift. So my question is this: should I just do the entire slab in 5in for building integrity, or are the footers enough? I've about maxed my budget with a 30x50x14, so I'm looking to get help where I can.
   / Concrete slab thickness vs.footers #2
What are you storing and driving in the barn? How heavy?
If you can identify now where your future lift would be I would go with thicker footings for that at specific area. You also might want to go thicker on the perimeter.
GP, as of now, I will not be storing anything other than 1/4T jeeps and WWII 1/2T Dodges. I do not plan on having any heavy machinery in the future.
   / Concrete slab thickness vs.footers #4
Pour 4" thick 4000 psi concrete, #4 rebar grid on 24" centers, 2" dobies to center the rebar vertically.
Use steel plates (24"x24" x 1" thick) under your lift columns to spread the load.
Good luck
   / Concrete slab thickness vs.footers #5
"(24"x24" x 1" thick)"
Flusher im not the original poster but I have a 4" thick already and was getting ready to do a very expensive retrofit. This will save me a ton of money
   / Concrete slab thickness vs.footers #6
Good luck
That sounds like a good plan.
   / Concrete slab thickness vs.footers #7
Given that concrete is running about a hundred bucks a yard, it's really cheap to dig a 2x2 foot footing under the place where the lift will be installed. If you have good soil, then a foot deep below the bottom of the pad should be plenty. If you have sand or other poor soils, then you really need to talk to a soils engineer because the variables make impossible for anybody who does not know your soil to be able to give good advice.
   / Concrete slab thickness vs.footers #8
Agree about what (earth) the concrete is sitting on...
Also, if the steel plate has to be purchased new...it's going to run close to $200 for each plate...hardly cheaper than concrete and rebar...
   / Concrete slab thickness vs.footers #9
but in my case cutting out a large section, reinforcing it to tie it back in and digging it out is way more expensive than the plate we are discussing.. For the OP it is sound advise.
   / Concrete slab thickness vs.footers #10
...For the OP it is sound advise...
I disagree...as long as the underlying strata is satisfactory and any disturbed earth is compacted a bell type footing under the support columns is easily the most cost efficient way to go...it is a tried and method that is standard in commercial building applications...
2020 Freightliner M2 106 Medium Duty Truck, VIN # 3ALACWFC3LDLS3099 (A55788)
2020 Freightliner...
Loader Bucket (A55787)
2016 PETERBILT 579 DAYCAB (A53843)
2016 PETERBILT 579...
2019 Allmand Bros Maxi-Lite II 15kW Towable Light Tower (A52377)
2019 Allmand Bros...
Ingersoll Rand PKG SS3660V 60 Gallon Air Compressor (A52377)
Ingersoll Rand PKG...
2014 Nissan Juke (A53424)
2014 Nissan Juke...
