Concrete repair
   / Concrete repair #1
woodlot
NW Wisconsin
NH 1920 w/7308 Loader
I need some advice on concrete repair. I've got a 1 1/2 year old slab in my pole barn. It's 4' thick, fiber refinnforced, and has hydronic heating (pex) tubing embeded within it. Anyway, I have some flaking & breaking of the top layer going on. This has occured around the floor drain and I think road salt draining off my truck has caused this. I'd like to repair it, espically to stop any future flaking/eroding. Any tips or help greatly appriciated! Thanks.
PS - its a small area, about 2 sq.ft. at this point.
   / Concrete repair #2
Wash it real well with lots of fresh water then dry throughly, remove as much loose material as you can and flood-coat the whole floor with epoxy?
   / Concrete repair #3
I'd suggest cleaning off the area using a wire brush or ?? and then apply a concrete friendly epoxy type coating/sealer. Can't advise on any brand names.
   / Concrete repair #4
It sounds to me like it is more of a problem with the concrete slump and the method of finish when the floor was poured. The epoxy paint may help but the fast and easy fix doesn't always work with concrete.
   / Concrete repair
I think you might be partially right BigTiller. The slab was poured in some pretty cold conditions. The building was heated, but I think a cold draft came through the floor drains. They were not completed yet. It is possible that the bad area around the drain froze during the curing process. Anyway, I need a good fix for this.....any more ideas? This is a 1700 sq ft barn and I've got about 2 sq ft of flaking.........I just don't want it to continue or spread.
JOHN DEERE 8R310 TRACTOR (A54756)
JOHN DEERE 8R310...
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
UNUSED DIGGIT 20'X20' HEAVY DUTY ALL-STEEL CARPORT (A54757)
UNUSED DIGGIT...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A55302)
John Deere 5090E...
2018 Chevrolet Colorado 4x4 Ext. Cab Pickup Truck (A53422)
2018 Chevrolet...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
